HP71b, time and af with adjust in one step - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP71b, time and af with adjust in one step (/thread-14905.html) |
HP71b, time and af with adjust in one step - Uli - 04-28-2020 07:05 PM Sorry, I am a really beginner. .. But I hang.... I want to "setime" and calculate a new "af" in one step. On page 95 (HP 71 Owner's Manual October 83) I find the description for "adjust" with an example. Main sentence: To perform all three operations at once, you execute the following. "adjust.....". following this discription no "exact" to calculate new af is needed. I think this is wrong. Are you with me? RE: HP71b, time and af with adjust in one step - Dave Frederickson - 04-28-2020 07:44 PM The example is for crossing a time zone, not correcting the adjustment factor. RE: HP71b, time and af with adjust in one step - Uli - 04-28-2020 07:56 PM The example to correct time because of time zone changing AND calculating a new af in one step by adjust. So, if there is no time zone change adjust should work to adjust time and af in one step, I thought. RE: HP71b, time and af with adjust in one step - Uli - 04-28-2020 07:58 PM Dave, thanks a lot. I was confused , because after executing adjust af has not changed. af has changed after executing adjust followed by exact. (I have had executed setime and exact some month ago) RE: HP71b, time and af with adjust in one step - Uli - 04-28-2020 08:19 PM Text from manual RE: HP71b, time and af with adjust in one step - Dave Frederickson - 04-28-2020 08:35 PM And I didn't read the whole example. The example describes only what ADJUST does and the use of EXACT is discussed in the paragraph before the example. So you are correct in that EXACT should follow the example use of ADJUST. For a thorough description of EXACT, ADJUST, and AF see the Reference Manual. Dave RE: HP71b, time and af with adjust in one step - Uli - 04-29-2020 05:49 PM Hi Dave, thanks a lot for your patience with me and your help. Greetings Uli |
