(50G) Question, has anyone programmed gauss's... - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: General Software Library (/forum-13.html) +--- Thread: (50G) Question, has anyone programmed gauss's... (/thread-1522.html) |
(50G) Question, has anyone programmed gauss's... - CosmicTruth - 06-02-2014 11:12 PM has anyone wrote program to solve gauss's shoelace formula with a 50G? http://en.wikipedia.org/wiki/Shoelace_formula RE: 50G Question, has anyone programmed gauss's... - Thomas Klemm - 06-03-2014 02:33 AM (06-02-2014 11:12 PM)CosmicTruth Wrote: has anyone wrote program to solve gauss's shoelace formula with a 50G? Code: \<< { [ 2 1 ] [ 4 5 ] [ 7 8 ] } Area = 3 RE: 50G Question, has anyone programmed gauss's... - CosmicTruth - 06-03-2014 11:02 AM (06-03-2014 02:33 AM)Thomas Klemm Wrote:(06-02-2014 11:12 PM)CosmicTruth Wrote: has anyone wrote program to solve gauss's shoelace formula with a 50G? Thanks for reply, whats GSLIST? the \GSLIST is erroring this, but nice code. i get 'GSLIST/2.' edit: GOTIT! the statistics EList function... this is good thanks RE: 50G Question, has anyone programmed gauss's... - Massimo Gnerucci - 06-03-2014 11:13 AM (06-03-2014 11:02 AM)CosmicTruth Wrote: Thanks for reply, whats GSLIST? \GSLIST == ∑LIST RE: 50G Question, has anyone programmed gauss's... - CosmicTruth - 06-03-2014 11:40 AM it works! thank you all so much for this code! i'm happy RE: 50G Question, has anyone programmed gauss's... - Thomas Klemm - 06-04-2014 07:03 AM This program is for the HP-42S: Code: 00 { 39-Byte Prgm } Example: Consider the polygon defined by the points (3,4), (5,11), (12,8), (9,5), and (5,6). 1 ENTER NEWMAT x: [ 1×1 Matrix ] 0 ENTER COMPLEX + x: [ 1×1 Cpx Matrix ] EDIT GROW 3 ENTER 4 COMPLEX → 5 ENTER 11 COMPLEX → 12 ENTER 8 COMPLEX → 9 ENTER 5 COMPLEX → 5 ENTER 6 COMPLEX EXIT x: [ 5×1 Cpx Matrix ] XEQ "AREA" y: [ 5×1 Cpx Matrix ] x: 30 RE: 50G Question, has anyone programmed gauss's... - CosmicTruth - 06-07-2014 12:41 PM (06-04-2014 07:03 AM)Thomas Klemm Wrote: This program is for the HP-42S: This is great and provided another great example, I have difficulty comparing the code or even seeing how it works because I don't have a 42S. I would have difficulty porting 42S code to my 50G, and I do wish 50G had "LBL" and "GOTO" like my old 41 did. I added a front end to the original 50G code above, so I can post it if anyone is interested? still a 50G work in progress but I have it asking for input and it stops and calculates if 0, 0 is entered. RE: 50G Question, has anyone programmed gauss's... - CosmicTruth - 06-07-2014 12:52 PM OK so after 30 seconds no one was interested but I'm going to post this 50G code anyhow in hopes someone will look at it and give some pointers... Code:
This just asks for input till 0,0 is input then calculates the area. Next (someday) I plan to sum the end areas into a volume using average end area * length. RE: 50G Question, has anyone programmed gauss's... - C.Ret - 09-21-2014 04:36 PM Here is a version for HP28S/C and any other old style RPL : Code:
