Pythagorean Triangle Search - Printable Version
+--- Forum: HP Prime Software Library (/forum-15.html)
+--- Thread: Pythagorean Triangle Search (/thread-15333.html)
Pythagorean Triangle Search - Eddie W. Shore - 07-12-2020 04:16 PM
Three Integers Make a Right Triangle
A Pythagorean triple is a trio of positive integers a, b, and c, that describe the lengths of a right triangle, where a and b are the lengths of the sides while c is the length of the hypotenuse.
The variables a, b, and c follow the Pythagorean Theorem:
a^2 + b^2 = c^2
Where the following measurements perimeter and area are calculated as:
p = perimeter = a + b + c
r = area = a * b / 2
With two positive integers m and n where m > n, Euclid gives a formula where a, b, and c are generated:
a = 2 * m * n
b = m^2 - n^2
c = m^2 + n^2
This can easily verified to satisfy the Pythagorean Theorem:
a^2 + b^2 = c^2
(2*m*n)^2 + (m^2 - n^2)^2 = (m^2 + n^2)^2
4*m^2*n^2 + m^4 - 2*m^2*m^2 + n^4 = m^4 + 2*m^2*m^2 + n^4
4*m^2*n^2 + m^4 - 4*m^2*m^2 + n^4 = m^4 + n^4
m^4 + n^4 = m^4 + n^4
The following program PYTHRI asks you for m and n and generates a Pythagorean triple. Make sure that m > n.
HP Prime Program PYTHRI
EXPORT PYTHTRI()
// 2020-06-13 EWS
// r: area
LOCAL a,b,c,p,r,m,n;
INPUT({m,n},"Pythagorean Triple
 Generator",{"m = ","n = "},
{"m > n, m,n ∈ Z+","m > n, m,n ∈ Z+"});
a:=2*m*n; b:=m^2-n^2; c:=m^2+n^2;
p:=a+b+c; r:=a*b/2;
PRINT();
PRINT(a+"^2+"+b+"^2="+c+"^2");
PRINT("a = "+a);
PRINT("b = "+b);
PRINT("c = "+c);
PRINT("perimeter = "+p);
PRINT("area = "+r);
Can We Go the Other Way?
Let's say we have the area and the perimeter of a right triangle. Can we find a Pythagorean triple? In order to do so, we need to solve for m and n, and make sure that m and n are positive integers.
Recall that:
a = 2 * m * n
b = m^2 - n^2
c = m^2 + n^2
Perimeter:
p = a + b + c
p = 2 * m * n + m^2 - n^2 + m^2 + n^2
p = 2 * m^2 + 2 * m * n
Area:
r = a * b / 2
r = m * n * (m^2 - n^2)
r = m^3 * n - m * n^3
Let's solve for n in the perimeter equation:
p - 2 * m^2 = 2 * m * n
Since m is a positive integer, m ≠ 0 and by dividing by 2 * m:
p / (2* m) - m = n
Substitute in the area equation:
r = m^3 * (p / (2* m) - m) - m * (p / (2* m) - m)^3
The program IPYTHTRI attempts to find a Pythagorean triple by solving for m in the above equation. A first initial guess of 0 is used, but the initial guess uses powers of 10 for any further iterations that are needed.
Should a triple not be found, the program will indicate the finding. Perfect search is not guaranteed.
If a suitable solution is found, then the program calculates and displays a, b, and c.
HP Prime Program IPYTHTRI
(inverse PYTHTRI)
EXPORT IPYTHTRI()
// 2020-06-13 EWS
// r: area
LOCAL a,b,c,p,r,m,n,k;
INPUT({p,a},"Pythagorean Triple
 Search",{"p = ","r = "},
{"perimeter","area"});
// search for integers
FOR k FROM 0 TO 7 DO
m:=fsolve(X^3*(p/(2*X)-X)
-X*(p/(2*X)-X)^3-a,X,10*k);
IF (FP(m)==0) AND (m>0) THEN
BREAK;
n:=p/(2*m)-m;
PRINT();
PRINT("m = "+m);
PRINT("n = "+n);
IF (FP(m)==0) AND (FP(n)==0) THEN
PRINT("Integer Solutions Found");
PRINT("a = "+a);
PRINT("b = "+b);
PRINT("c = "+c);
ELSE
PRINT("No integer solutions found");
Examples
(p = perimeter, r = area)
m = 5, n = 3
a = 30, b = 16, c = 34
p = 80, r = 240
m = 11, n = 6
a = 132, b = 85, c = 157
p = 374, r = 5610
m = 18, n = 14
a = 504, b = 128, c = 520
p = 1152, r = 32256
m = 164, n = 133
a = 43624, b = 9207, c = 44585
p = 97416, r = 200,823,084
Source:
Pythagorean triple. Wikipedia. Last Edited June 13, 2020. https://en.wikipedia.org/wiki/Pythagorean_triple Accessed June 13, 2020
Eddie
http://edspi31415.blogspot.com/2020/07/hp-prime-pythagorean-triangle-search.html
