[split] Help with update - Printable Version
+--- Thread: [split] Help with update (/thread-15378.html)
[split] Help with update - Christian Choque - 07-25-2020 11:32 PM
Regards. Maybe someone could help me, I installed the new firmware of hp 2.1.14425 of my calculator but I had a problem a week with the calculator, it turned off and did not want to start I could not start it either by using the combination C, F, O + on or the Reset function until you remove the battery. In addition to that error, I observed a very frequent and noticeable flickering during the use of CAS, so perhaps they could recommend an earlier version of the more stable firmware, please.
RE: [split] Help with update - robmio - 07-27-2020 12:24 PM
Hi, what version of HP PRIME do you have: G1 or G2? If you have the HP PRIME G2, why don't you try to update the firmware with version 2.1.14433 (2020 01 21)?
See: https://www.hpcalc.org/details/7783
