(41C) and (42S) Arithmetic-Geometric Mean - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: General Software Library (/forum-13.html) +--- Thread: (41C) and (42S) Arithmetic-Geometric Mean (/thread-15384.html) |
(41C) and (42S) Arithmetic-Geometric Mean - Eddie W. Shore - 07-26-2020 07:50 PM Arithmetic-Geometric Mean The program AGM calculates the arithmetic-geometric mean of two positive integers x and y. As the graphic above suggests, an iterative process is used to find the AGM, computing both the arithmetic mean and geometric mean until the two means converge. a0 = x g0 = y Repeat: Arithmetic Mean: a1 = (a0 + g0)/2 Geometric Mean: g1 = √(a0 * g0) Transfer new to old: a0 = a1, g0 = g1 Until |a1 - g1| < tolerance You can set the tolerance as low as you want. The programs presented on this blog set tolerance at 10^(-10) (1E-10), to fit the calculator's display. HP 41C Program: AGM 01 LBL^T AGM 02 STO 01 03 X<>Y 04 STO 02 05 X<>Y 06 LBL 00 07 RCL 02 08 RCL 01 09 ENTER 10 R↑ 11 R↑ 12 X<>Y 13 R↓ 14 ENTER 15 R↑ 16 + 17 2 18 / 19 STO 01 20 R↓ 21 * 22 SQRT 23 STO 02 24 R↑ 25 - 26 ABS 27 1E-10 28 X≤Y? 29 GTO 00 30 CLA 31 ^T AGM = 32 ARCL 01 33 AVIEW 34 END HP 42S/Swiss Micros DM42/Free42 Program AGM: 00 {53-Byte Prgm} 01 LBL "AGM" 02 STO 01 03 X<>Y 04 STO 02 05 X<>Y 06 LBL 00 07 RCL 02 08 RCL 01 09 ENTER 10 R↑ 11 R↑ 12 X<>Y 13 R↓ 14 ENTER 15 R↑ 16 + 17 2 18 / 19 STO 01 20 R↓ 21 * 22 SQRT 23 STO 02 24 R↑ 25 - 26 ABS 27 1E-10 28 X≤Y? 29 GTO 00 30 CLA 31 "AGM = " 32 ARCL 01 33 AVIEW 34 END The instructions for both the HP 41C and 42S versions are same: enter X and Y on the respective stacks and XEQ AGM. Example (ALL/STD mode is applied): AGM(37, 78): 37, 78, XEQ AGM returns: Alpha: AGM = 55.5947005279 Blog Post: http://edspi31415.blogspot.com/2020/07/hp-41c-hp-42s-ti-60-arithmetic.html RE: (41C) and (42S) Arithmetic-Geometric Mean - Werner - 07-27-2020 07:26 AM In a lengthy thread about bore hole volumes not so long ago, I came up with the following, thanks to Albert Chan and Gerson W. Barbosa (stack-only, 41/42 compatible and reg Z preserved): Code: 00 { 27-Byte Prgm } @ X Y Z T I you want to show "AGM=.." at the end, for Free42 and DM42 there's a way that does not use the Alpha register: just add LSTO "AGM" VIEW "AGM" at the end. Cheers, Werner RE: (41C) and (42S) Arithmetic-Geometric Mean - Albert Chan - 07-29-2020 11:37 AM Originally, Werner's code return converged AM sequence. (06-09-2020 01:14 PM)Albert Chan Wrote: If we assume non-zero AGM arguments, AM sequence always converge. We can shown GM sequence also converge. (even with rounding errors) Assuming it does not, but alternate between lo, hi. In other words, GM sequence = GM1, GM2, ..., lo, hi, lo, hi, ... But, √(lo * hi) = √(hi * lo) Thus, we have only 2 possibilities: 1). GM1, GM2, ..., lo, hi, lo, lo, ... 2). GM1, GM2, ..., lo, hi, hi, hi, ... → assumption were wrong, GM *will* converge. Bonus: GM convergence does not require non-zero AGM arguments. → AGM(x, 0) = AGM(0, x) = 0 RE: (41C) and (42S) Arithmetic-Geometric Mean - Werner - 07-29-2020 12:53 PM But the next GM in the sequence is not calculated as sqrt(lo*hi)? but as SQRT(GMi*AMi) Werner RE: (41C) and (42S) Arithmetic-Geometric Mean - Albert Chan - 07-29-2020 02:35 PM (07-29-2020 12:53 PM)Werner Wrote: But the next GM in the sequence is not calculated as sqrt(lo*hi)? but as SQRT(GMi*AMi) My mistake. I wrongly assumed AM converged to lo or hi too. Proof (2nd attempt): Again, assume GM sequence do not converge, but alternate between lo, hi GM sequence = GM1, GM2, ..., lo, hi, lo, hi, ... For big enough i, such that GM(i) = lo, and AM(i) converged to g: GM(i+1) = hi = √(g*lo) GM(i+2) = lo = √(g*hi) If hi > lo, we have √(g*lo) > √(g*hi), which is impossible, even with rounding errors. → when AM converged, GM sequence is non-decreasing, will converge too. |
