"Counting in their heads" - 1895 oil painting - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: "Counting in their heads" - 1895 oil painting (/thread-15446.html) Pages: 1 2 |
"Counting in their heads" - 1895 oil painting - EdS2 - 08-08-2020 05:29 PM There's a mental arithmetic challenge in this painting - see below for a plain rendering. ![]() The challenge is - and I have run this through my own brain, and it's not unfair: ![]() Which is to say, calculate (10²+11²+12²+13²+14²)/365 It's hardly worth noting that this is very easy with a calculator. (via TYWKIWDBI) RE: "Counting in their heads" - 1895 oil painting - grsbanks - 08-08-2020 07:14 PM That's quite fun, in fact, because as you're partway through it, you realise that 10^2+11^2+12^2=365 and also that 13^2+14^2=365 So I make the answer 2 ![]() RE: "Counting in their heads" - 1895 oil painting - Albert Chan - 08-08-2020 07:42 PM (08-08-2020 05:29 PM)EdS2 Wrote: calculate (10²+11²+12²+13²+14²)/365 With only 5 terms, it is trivial to calculate. (x-y)² + (x+y)² = 2(x²+y²) 12² + (11²+13²) + (10²+14²) = 5*12² + 2*(1+4) = 730 730/365 = 2 --- Here is a way to fit it to polynomial, then "integrate" (see Funny Factorial and Slick Sums) We know f(x) is quadratic, thus only 3 points needed. Code: x f(x) Δ Δ² \(f(x) = 100 + 21\binom{x}{1} + 2\binom{x}{2}\) \(F(x) = \sum_{t=0}^{x-1} f(t) = 100\binom{x}{1} + 21\binom{x}{2} + 2\binom{x}{3}\) F(5)/365 = (100*5 + 21*10 + 2*10) / 365 = 730/365 = 2 RE: "Counting in their heads" - 1895 oil painting - EdS2 - 08-09-2020 07:33 AM Indeed, grsbanks, I too had a sense of impending relief as I summed the last two terms first (for no special reason.) But Albert, you have been much more mathematical! Thanks for the link to your thread, which in turn links to some older threads. Some good material in there. I'm tempted to say that if I were the same distance from 16 as I am presently from 60 I might have been able to see deeper into this challenge. It seems my head is now filled with pink blancmange. RE: "Counting in their heads" - 1895 oil painting - Albert Chan - 08-09-2020 12:19 PM (08-08-2020 07:42 PM)Albert Chan Wrote: \(F(x) = \sum_{t=0}^{x-1} f(t) = 100\binom{x}{1} + 21\binom{x}{2} + 2\binom{x}{3}\) Another way to get F(x), via Triangular numbers \(\sum_{x=1}^n \binom{x+0}{1} = \binom{n+1}{2} \) // triangular numbers \(\sum_{x=1}^n \binom{x+1}{2} = \binom{n+2}{3} \) // sum of triangular numbers 10² + 11² + 12² + 13² + 14² = 10² + (10²+21) + (10²+21+23) + (10²+21+23+25) + (10²+21+23+25+27) = 100*5 + 21*4 + 23*3 + 25*2 + 27*1 = 100*5 + 21*(4+3+2+1) + 2*(1+1+1+2+2+3) = 100*5 + 21*(1+2+3+4) + 2*(1+(1+2)+(1+2+3)) = \(100\binom{5}{1} + 21\binom{5}{2} + 2\binom{5}{3}\) This matched the quoted F(x) equation, thus gives the same answer RE: "Counting in their heads" - 1895 oil painting - Albert Chan - 08-09-2020 02:24 PM An elegant way to get sum of squares formula is with geometry. ![]() sum-of-n-squares = 1/3 * (2*n+1) * n*(n+1)/2 = n*(n+1)*(2*n+1)/6 Falling factorial derivation is also simple: s(x) = x² = x + x*(x-1) = x1 + x2 S(x) = Σ(s(t), t=0 .. x-1) = x2/2 + x3/3 = x*(x-1)*(1/2 + (x-2)/3) = x*(x-1)*(2*x-1)/6 // note: sum-of-n-squares = S(n+1) 10²+11²+12²+13²+14² = S(15) - S(10) = 15*14*(30-1)/6 - 10*9*(20-1)/6 = 35*(30-1) - 15*(20-1) = (1050-300) - (35-15) = 730 RE: "Counting in their heads" - 1895 oil painting - Gerson W. Barbosa - 08-09-2020 08:11 PM Alternatively, you can use this formula: n[c + (n² - 1)/12] where n is the number of elements in the sequence and c is the central element. 5[12² + (5² - 1)/12] = 5[144 + 2] = 730 This should work also for sequences with even number of elements. For instance, 5² + 6² + 7² + 8² = 4[6.5² + (4² - 1)/12] = 174 A bit more difficult to do it in one’s head, though. RE: "Counting in their heads" - 1895 oil painting - Gerson W. Barbosa - 08-10-2020 11:50 AM \( \frac{{55}^{2}+{65}^{2}+{75}^{2}+{85}^{2}+{95}^{2}+{105}^{2}+{115}^{2}+{125}^{2}+{135}^{2}+{145}^{2}}{10825}\) Also easily done, when you know the right formula :-) RE: "Counting in their heads" - 1895 oil painting - Albert Chan - 08-10-2020 12:49 PM (08-10-2020 11:50 AM)Gerson W. Barbosa Wrote: \( \(s(x) = (a+bx)^2 = a^2 + 2abx + b^2x^2 = a² + b(2a+b)\binom{x}{1} + 2b^2\binom{x}{2}\) → Σ(s(x), x=0..n-1) = [a², b(2a+b), 2b²] • [nC1, nC2, nC3] With a=55, b=10, n=10 S = [a², b(2a+b), 2b²] • [nC1, nC2, nC3] = [3025, 1200, 200] • [10, 45, 120] = 30250 + 54000 + 24000 = 108250 → S / 10825 = 10 --- We can also use central element, c = a + b(n-1)/2 → S = c²n + b²(n+1)(n)(n-1)/12 With c = (55+145)/2 = 100, b=10, n=10: S = 100²*10 + 10²*11*10*9/12 = 100000 + 8250 = 108250 Or, simply force b=1 (55² + 65² + ... + 145²) / 10825 = (5.5² + 6.5² + ... + 14.5²) / 108.25 // c=n=10 = (1000 + 11*10*9/12) / 108.25 = 10 RE: "Counting in their heads" - 1895 oil painting - Albert Chan - 08-10-2020 03:06 PM (08-09-2020 08:11 PM)Gerson W. Barbosa Wrote: This should work also for sequences with even number of elements. For instance, "Central element" can be any number, even irrationals. \(s(x) = (x+a)^2 = a^2 + 2ax + x^2 = a^2 + (2a+1)\binom{x}{1} + 2\binom{x}{2}\) For sum of n consecutive squares, starting from a^2: XCas> S(a,n) := [a^2, 2*a+1, 2] * [n, n*(n-1)/2, n*(n-1)*(n-2)/6] XCas> expand(S(a,n)) → n^3/3+a*n^2+a^2*n-n^2/2-a*n+n/6 S(a,n) = S(0,a+n-0) - S(0,a). What happens if we replace 0 by c ? XCas> expand(S(c,a+n-c) - S(c,a-c)) → n^3/3+a*n^2+a^2*n-n^2/2-a*n+n/6 c got *eliminated*, giving same expression as S(a,n) ![]() For exact center, c = a+(n-1)/2, we got a nice compact formula XCas> simplify(S(c-(n-1)/2, n)) → (12*c^2*n+n^3-n)/12 --- Since we can pick any c, lets try summing T = 88² + 89² + ... + 115², with c=100 [c^2, 2*c+1, 2] = [10000, 201, 2] \([\binom{16}{1}, \binom{16}{2}, \binom{16}{3}] - [\binom{-12}{1}, \binom{-12}{2}, \binom{-12}{3}]\) = [16,120,560] - [-12,78,-364] = [28,42,924] T = [10000, 201, 2] • [28,42,924] = 280000 + 8442 + 1848 = 290290 Confirm above with exact center: c = (88+115)/2 = 203/2, n = 115-88+1 = 28 T = c²n + (n+1)(n)(n-1)/12 = (203/2)²*28 + 29*28*27/12 = 203²*7 + 29*7*9 = (41209 + 261)*7 = 290290 RE: "Counting in their heads" - 1895 oil painting - Albert Chan - 08-10-2020 04:33 PM (08-10-2020 03:06 PM)Albert Chan Wrote: XCas> expand(S(c,a+n-c) - S(c,a-c)) → n^3/3+a*n^2+a^2*n-n^2/2-a*n+n/6 We never assume variables as integer. Formula work even if they are not. ![]() sum-of-n-squares = n*(n+1)*(2*n+1)/6 = \(\binom{2(n+1)}{3}/4\) // 1/4 of tetrahedral numbers, side 2n Formula is meaningless for non-integer, but the difference still gives S(a,n). XCas> expand(simplify(comb(2*(a+n),3)/4 - comb(2*a,3)/4)) → n^3/3+a*n^2+a^2*n-n^2/2-a*n+n/6 (55² + 65² + ... + 145²) / 10825 = (5.5² + 6.5² + ... + 14.5²) / 108.25 = \( \Large {\binom{31}{3} - \binom{11}{3} \over 4×108.25}\\ \) = (4495 - 165 ) / 433 = 10 RE: "Counting in their heads" - 1895 oil painting - Gerson W. Barbosa - 08-11-2020 12:33 AM It looks like we can proceed to the next level: \( \frac{{10}^{3}+{11}^{3}+{12}^{3}+{13}^{3}+{14}^{3}}{450} \) RE: "Counting in their heads" - 1895 oil painting - Pjwum - 08-11-2020 08:24 AM I have to admit, I admired this wonderful piece of art more than diving into the mathematical task. It reminds me very much of my old school days. Some of us strongly trying to have the first answer. Some staring at the board to find a smart solution (or pretending to do so). The desperated one. And always the same guys sucking up to the teacher. Ahh, the teacher! He seems to be ostentatiously relaxed, waiting patiently to grant every child a chance of success. Did you notice the tonal scale beside the board. It is smaller but seems equally important. A balance of logic and arts. Ok, but this is a calculator forum. RE: "Counting in their heads" - 1895 oil painting - EdS2 - 08-11-2020 09:37 AM It is a calculator forum, but there's an intersection: the prodigal calculator. This is W. W. Rouse Ball writing about George Parker Bidder: Quote:Halfpence rewarded his efforts, and by the time he was eight years old, he could multiply together two numbers each of six digits. In one case he even multiplied together two numbers each of twelve digits, but, he says, "it required much time," and "was a great and distressing effort." RE: "Counting in their heads" - 1895 oil painting - Albert Chan - 08-11-2020 10:39 AM (08-11-2020 12:33 AM)Gerson W. Barbosa Wrote: It looks like we can proceed to the next level: Sum of cubes = squared triangular number = \(\binom{n+1}{2}^2\) S = (10³+11³+12³+13³+14³) = \(\binom{15}{2}^2 - \binom{10}{2}^2\) = (105-45)*(105+45) = 60*150 = 9000 → S/450 = 20 --- We can rewrite formula in terms of central element, c = a + (n-1)/2 (x+y)³ + (x-y)³ = (x³+3x²y+3xy²+y³) + (x³-3x²y+3xy²-y³) = 2x³+6xy² sum-of-n-cubes \(= c^3 n + 6c×(1^2 + 2^2 + \cdots + ({n-1\over2})^2) = c^3 n + 6c × \binom{n+1}{3}/4 \) → sum-of-n-cubes = cn*(c² + (n²-1)/4) S = 12*5*(12² + (4*6)/4) = 60*150 = 9000 RE: "Counting in their heads" - 1895 oil painting - Gerson W. Barbosa - 08-11-2020 12:43 PM (08-11-2020 10:39 AM)Albert Chan Wrote: → sum-of-n-cubes = cn*(c² + (n²-1)/4) That’s equivalent to what I’ve come up with, except that I have introduced a factor to generalize for evenly spaced sequences: sum-of-n-cubes = nc(c² + d²(n² - 1)/4) where n = number of elements in the evenly spaced sequence c = central element d = interval distance For example, S = 33³ + 40³ + 47³ + 54³ + 61³ + 68³ n = 6 c = (33 + 68)/2 = 50.5 d = (68 - 33)/(n - 1) = 7 S = 6×50.5(50.5² + 7²(6² - 1)/4) = 902637 Likewise, sum-of-n-squares = n(c² + d²(n² - 1)/12) Considering the similarities between both formulae, perhaps they somehow can be generalized for all positive integer powers. RE: "Counting in their heads" - 1895 oil painting - Albert Chan - 08-11-2020 03:06 PM (08-11-2020 10:39 AM)Albert Chan Wrote: Sum of cubes = squared triangular number = \(\binom{n+1}{2}^2\) Proof: f(x) = x³ = (x³-x) + x = (x+1)3 + x1 F(x) = (x+1)4/4 + x2/2 = \(\binom{x}{2} × {(x+1)(x-2) + 2 \over 2} = \binom{x}{2}^2\) sum-of-n-cubes = F(n+1) = \(\binom{n+1}{2}^2\) (08-11-2020 10:39 AM)Albert Chan Wrote: sum-of-n-cubes \(= c^3 n + 6c×(1^2 + 2^2 + \cdots + ({n-1\over2})^2) Although above formula assumed (n-1)/2 is integer, this is not necessary. XCas> S(a,n) := simplify(sum((a+x)^3, x=0..n-1)) XCas> factor(S(c-(n-1)/2,n)) → n*c*(4*c^2+n^2-1)/4 Again, any "central element" work, with differences back to S(a,n) XCas> simplify(S(c,a+n-c) - S(c,a-c) - S(a,n)) → 0 Redo previous example, using simple sum-of-n-cubes formula (c=1) S = 33³ + 40³ + 47³ + 54³ + 61³ + 68³ = 7³ * ((33/7)³ + (33/7+1)³ + ... + (68/7)³) = \(7^3 \left(\binom{75/7}{2}^2 - \binom{33/7}{2}^2) \right)\) = \(\Large{(75×68)^2 - (33×26)^2 \over 7×4}\) = 902637 RE: "Counting in their heads" - 1895 oil painting - Albert Chan - 08-11-2020 05:07 PM (08-11-2020 12:43 PM)Gerson W. Barbosa Wrote: sum-of-n-squares = n(c² + d²(n² - 1)/12) Perhaps this explain the similarity, for Sp = ap + (a+1)p + ... + bp, b = a+n-1 With center c = (a+b)/2, g = (n-1)/2 = b-c = c-a, we have S(a,n) = S(c,b-c+1) - S(c,a-c) = S(c,g+1) - S(c,-g) = Finite-Difference-Diagonals • \(\left( [\binom{g+1}{1},\binom{g+1}{2},\cdots] - [\binom{-g}{1},\binom{-g}{2},\cdots] \right)\) Let's see what the combinatorial coefficients look like: XCas> g := (n-1)/2 XCas> coef := makelist(r -> simplify(comb(g+1,r) - comb(-g,r)),1,6) → \(\Large [n,\,0,\,\frac{(n^{3}-n)}{24},\,\frac{(-n^{3}+n)}{24},\,\frac{(n^{5}+70\cdot n^{3}-71\cdot n)}{1920},\,\frac{(-n^{5}-30\cdot n^{3}+31\cdot n)}{960}]\) coef(1) = n, which make first term of Sp = c^p*n coef(2) = 0, which make the central element based formula compact (Δf * 0 = 0) coef(3) = -coef(4), which meant dot-products have this common factor. Finite Difference table for (c+x)² and (c+x)³ // note: [1,0,0] ≡ c², [1,2,1] ≡ c²+2c+1 Code: x (c+x)^2 If we let k = coef(3) = (n³-n)/24: sum-of-n-squares = c^2*n + 2k sum-of-n-cubes = c^3*n + (6c+6)*k + 6*(-k) = c*(c^2*n + 6k) coef(4) and coef(5) are not close, which meant similarity ends after cubes XCas> sumpow(p) := expand(simplify(sum(x^p, x=c-g .. c+g))) XCas> for(p=1; p<6; p++) {print(p, sumpow(p))} 1, c*n 2, (n^3)/12+c^2*n-n/12 3, (c*n^3)/4+c^3*n-(c*n)/4 4, (n^5)/80+(c^2*n^3)/2+c^4*n-(n^3)/24-(c^2*n)/2+(7*n)/240 5, (c*n^5)/16+(5*c^3*n^3)/6+c^5*n-(5*c*n^3)/24-(5*c^3*n)/6+(7*c*n)/48 RE: "Counting in their heads" - 1895 oil painting - Gerson W. Barbosa - 08-11-2020 11:53 PM (08-11-2020 09:37 AM)EdS2 Wrote: It is a calculator forum, but there's an intersection: the prodigal calculator. IMHO, this does belong in the General Forum: Quote:General Forum Thank you very much for posting! Gerson. RE: "Counting in their heads" - 1895 oil painting - Albert Chan - 08-12-2020 01:32 AM I was wrong. There seems to be a pattern to sum of powers formula after all ... \( S_p = n c^p + \large {n^3-n \over 12} \left( \binom{p}{2} c^{p-2} + {3n^2-7 \over 20} \binom{p}{4} c^{p-4} + {3n^4-18n^2+31 \over 112} \binom{p}{6} c^{p-6} + {5n^6-55n^4+239n^2-381 \over 960} \binom{p}{8} c^{p-8} + \cdots \right) \) Example: 50^5 + 51^5 + 52^5 + ... + 150^5 // p=5, c=100, n=101 = 101*100^5 + 102*101*100/12 * (10*100^3 + (3*101^2-7)/20*5*100) = 1934166665000 |
