"Counting in their heads" - 1895 oil painting - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: "Counting in their heads" - 1895 oil painting (/thread-15446.html) Pages: 1 2 |
RE: "Counting in their heads" - 1895 oil painting - Albert Chan - 08-12-2020 01:50 PM There is also a pattern for sp (see Benoulli Number thread) \(s_p(n) = \sum_{x=0}^{n-1}x^p = \large {n^{p+1}\over p+1} - {n^p \over 2} + {p\over12}(n^{p-1}) + k_{p-3}(n^{p-3}) + k_{p-5}(n^{p-5}) + \cdots \) sp(1) = sp(0) + 0^p = sp(0) = 0 ⇒ above formula does not have a constant term ⇒ when p is odd, p>1, sp(n) has factor n² Redo previous example: s5(n) = n^6/6 - n^5/2 + 5/12*n^4 + k2*n^2 s5(1) = 1/6 - 1/2 + 5/12 + k2 = 0 → k2 = -1/12 → s5(n) = (2*n^6 - 6*n^5 + 5*n^4 - n^2) / 12 T = 50^5 + 51^5 + 52^5 + ... + 150^5 = s5(151) - s5(50) = 1936617185625 - 2450520625 = 1934166665000 Update: we may use this to help mental calculation: For n ≥ 0, sp(n) = (-1)p+1 * sp(1-n) Redo above example, using s5(151) = s5(-150), and horner's rule Code: b = -150 Update: we are better off using Euler-Maclaurin formula, which work for any f(x) Note: coefficients were B(1)/1! = -1/2, B(2)/2! = 1/12, B(4)/4! = -1/720, ... Σf = Δ-1 f = (eD-1)-1 f = (D-1 - 1/2 + D/12 - D³/720 + ...) f Example, with f = x^5 s5 = ∫f dx - f/2 + f'/12 - f'''/720 + ... = x^6/6 - x^5/2 + (5x^4)/12 - (60x^2)/720 RE: "Counting in their heads" - 1895 oil painting - Albert Chan - 08-13-2020 03:50 PM There is also the Faulhaber polynomials, with sum-of-powers formula as function of triangular number. Let \(\large t = \binom{x}{2},\;{s_{2m} \over (2x-1)t}\) and \(\large {s_{2m+1} \over t^2}\) are polynomial of t, degree m-1 Example, get s4(x) and s5(x) in terms of t, using divided difference. Note: we start from x=2, instead of 0, to avoid divide-by-zero issue. Code: x s4(x) | t s4/(2xt-t) divided-diff Redo previous example, using horners rule for the difference. Code: lua> a,b = 50, 151 -- next line replaced with t's RE: "Counting in their heads" - 1895 oil painting - Albert Chan - 08-14-2020 02:25 PM (08-12-2020 01:32 AM)Albert Chan Wrote: I was wrong. There seems to be a pattern to sum of powers formula after all ... To extend formula for spacings = d, simply replace Sp by Sp/dp, c by c/d Or, just check the dimensions for each term. All terms must have same units. Example, for sum-of-squares, all terms should have unit of c² S2 = n*c² + (n³-n)/12 * d² // c/d is dimensionless, thus c, d have same unit Example, for sum of m odd squares 1² + 3² + 5² + ... + (2m-1)² // d=2, c = m = n = m*m² + m*(m²-1)/12 * 2² = m*(4m²-1)/3 = \(\binom{2m+1}{3}\) We can confirm this from sum-of-n-squares formula \(\begin{align} {n(n+1)(2n+1) \over 6} &= {n(n+1)·[(n-1) + (n+2)] \over 6}\\ \binom{2n+2}{3}/4 &= \binom{n+1}{3} + \binom{n+2}{3}\\ \end{align}\) Let n = 2m: LHS = sum-of-m-odd-squares + sum-of-m-even-squares \(\binom{n+2}{3}\) = 4×sum-of-m-squares = sum-of-m-even-squares ⇒ \(\binom{2m+1}{3}\) = sum-of-m-odd-squares RE: "Counting in their heads" - 1895 oil painting - rprosperi - 08-14-2020 07:20 PM C'mon now Albert... Is all this really 'in your head'? Seems like many whiteboards... RE: "Counting in their heads" - 1895 oil painting - Gerson W. Barbosa - 08-15-2020 02:55 AM (08-13-2020 03:50 PM)Albert Chan Wrote: There is also the Faulhaber polynomials, with sum-of-powers formula as function of triangular number. Indeed there is more than a way to skin a cat (if we still may say that these days). There is also Hurwitz zeta function. For example, ζ(-5, 50) - ζ(-5, 151) = 1934166665000 But what calculator has that built-in? RE: "Counting in their heads" - 1895 oil painting - Joe Horn - 08-15-2020 05:04 AM (08-15-2020 02:55 AM)Gerson W. Barbosa Wrote: There is also Hurwitz zeta function. Anybody know which zeta function Prime's CAS uses when Zeta() is given two arguments? Prime evaluates Zeta(2,2) as 1.9892802343, but Wolfram Alpha returns pi^2/6-1 (approx 0.644934) for HurwitzZeta(2,2). Prime's Help screen for Zeta() does not mention a two-argument syntax, so it's a mystery to me. RE: "Counting in their heads" - 1895 oil painting - Gerson W. Barbosa - 08-15-2020 07:20 AM (08-15-2020 05:04 AM)Joe Horn Wrote: Anybody know which zeta function Prime's CAS uses when Zeta() is given two arguments? That’s the derivative of Zeta function. The second argument is the derivative order. In W|A: (d^2 ζ(x))/(dx^2), x = 2 |
