(25) Frequency Synthesis IC - Printable Version
+--- Forum: General Software Library (/forum-13.html)
+--- Thread: (25) Frequency Synthesis IC (/thread-15495.html)
(25) Frequency Synthesis IC - SlideRule - 08-23-2020 01:05 PM
An extract from 1980 Plessey Frequency Synthesis IC Handbook, Plessey Semiconductors, SEPTEMBER 1980 {pgs. 61-64}
" 1. Product Information
Using a calculator to find the division numbers of the NJ8811 and NJ8812
Programming the NJ8811
The NJ8811 requires a sixteen bit binary address to program the division number …
If a Hewlett Packard 25 or equivalent calculator is available the following program (Table 2) may be used to obtain the decimal equivalent directly from the frequency and channel spacing … pg. 62
Programming the NJ8812
The NJ8812 requires a fourteen bit binary address to program the division number …
If a Hewlett Packard 25 or equivalent calculator is available the following program may be used to obtain the Decimal equivalent directly from the frequency and channel spacing … pgs. 63-64"
BEST!
SlideRule
