HP Prime Python reference guide and tutorial? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: HP Prime Python reference guide and tutorial? (/thread-15507.html) |
HP Prime Python reference guide and tutorial? - GadgetguyToronto - 08-27-2020 08:28 PM Hello, I am looking for an HP Prime Python tutorial and / or reference guide (for the python implementation incorporated in the CAS). Would you have any pointers please? Thank you! RE: HP Prime Python reference guide and tutorial? - rawi - 08-28-2020 04:01 PM Hi, Python is not included in the HP Prime. Instead the Prime has a special programming language which is similar to Pascal. A reference for this can be found under the following link: https://support.hp.com/us-en/product/hp-prime-graphing-calculator/5367459/model/5367460/manuals Best Raimund RE: HP Prime Python reference guide and tutorial? - toml_12953 - 08-28-2020 04:06 PM (08-28-2020 04:01 PM)rawi Wrote: Hi,CAS accepts some Python commands. The entire language isn't in there but you can write some CAS programs that look a lot like Python. RE: HP Prime Python reference guide and tutorial? - GadgetguyToronto - 08-28-2020 09:47 PM (08-28-2020 04:06 PM)toml_12953 Wrote:(08-28-2020 04:01 PM)rawi Wrote: Hi,CAS accepts some Python commands. The entire language isn't in there but you can write some CAS programs that look a lot like Python. Thank you, that is exactly what I am talking about. Where is this documented? What commands can be used? RE: HP Prime Python reference guide and tutorial? - pinkman - 08-29-2020 09:40 AM Well Python-like syntax is understood by the CAS, probably because XCas understands it also. But it is limited, see Parisse’s answer in this thread: https://www.hpmuseum.org/forum/thread-9481-post-83159.html#pid83159 I don’t think there is a reference guide for Python/CAS programming. Try yourself: create a CAS program and use Python syntax, if you’re not trying to import Python modules, it will work fine. RE: HP Prime Python reference guide and tutorial? - MikeSD - 01-04-2024 05:32 PM (08-28-2020 04:01 PM)rawi Wrote: Hi,This is not entirely true. There is an app on the latest update, that includes something like MicroPython, and does run a version. The question is still valid, as far as I can tell. But there does't seem to be any documentation. I can't even find documentation, anywhere, that even tells how to use the Python App. HP sure has slipped with regards to providing documentation. RE: HP Prime Python reference guide and tutorial? - StephenG1CMZ - 01-04-2024 06:36 PM (01-04-2024 05:32 PM)MikeSD Wrote:(08-28-2020 04:01 PM)rawi Wrote: Hi,This is not entirely true. There is an app on the latest update, that includes something like MicroPython, and does run a version. That app "on the latest update", is available on the actual HP Prime, but not on the latest update of the Android App. Last year's mention of a possible update (to the 2021 Android version) have yet to happen. There have been several tips on using Python in this forum, but little formal documentation. The Python-in-CAS syntax may be described in XCAS documentation. |
