HP-41 Book "Programming the HP 41C/CV/CX" by Thomas Adams - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP-41 Book "Programming the HP 41C/CV/CX" by Thomas Adams (/thread-15513.html) Pages: 1 2 |
RE: HP-41 Book "Programming the HP 41C/CV/CX" by Thomas Adams - AndiGer - 10-02-2020 06:42 AM Ships from Sterling, Virginia while Allen's location is Virginia ... Quite sure it is the same book RE: HP-41 Book "Programming the HP 41C/CV/CX" by Thomas Adams - Allen - 10-02-2020 09:03 PM Greetings, the copyright holders agreed to include in the Museum DVD, but I did not ask permission to post in the forum. I feel the table of contents is fair use as it describes the contents of the book itself, but I'd feel more comfortable NOT posting the entire book, as it's outside what I requested from his estate. I may revisit that later in the year, if an opportunity arises, and I think it will. There is a possibility we could have more of Dr. Adams' work to scan in the coming months, so maybe don't buy the updated ThumbDrive/DVD TOO soon?? I bought a new Epson ES400 scanner for this project and digitized/OCR/Bookmarked some other HP manuals (e.g. 41C Test Statistics and a Catalog of Users' Programs from 1985) that were not on the DVD. RE: HP-41 Book "Programming the HP 41C/CV/CX" by Thomas Adams - Dave Frederickson - 10-02-2020 09:13 PM (10-02-2020 09:03 PM)Allen Wrote: I bought a new Epson ES400 scanner for this project and digitized/OCR/Bookmarked some other HP manuals (e.g. 41C Test Statistics and a Catalog of Users' Programs from 1986) that were not on the DVD. Have you looked into using a camera to digitize books and manuals? As an example of the quality of the finished product, the Portable PLUS Service manual, was scanned with a smartphone and an app that corrects for trapezoidal effects, etc. http://www.jeffcalc.hp41.eu/hpplus/files/servicemanual.pdf There are some fancy platforms/light tables available for the serious minded. Dave RE: HP-41 Book "Programming the HP 41C/CV/CX" by Thomas Adams - Allen - 10-02-2020 09:17 PM With a table saw and a sheet-fed scanner there's very few books one can't scan. RE: HP-41 Book "Programming the HP 41C/CV/CX" by Thomas Adams - Eric Rechlin - 10-02-2020 10:30 PM You should ask permission to post it on the forum! Sounds like you have a similar setup to me. I considered the Epson but ended up buying a Fujitsu FI-7160 instead. It does a fantastic job scanning manuals (60 pages per minute at 300 dpi with both sides scanned, and still quite fast at 600 dpi!), and is almost as good as a flatbed for photos, too (only a little streaking in some dark areas, which is hard to avoid with sheet feeders). Also, I use a Martin Yale 7000e stack paper cutter for cutting off bindings. It will cut a phone book in half like going through butter with a warm knife. Very clean cuts. RE: HP-41 Book "Programming the HP 41C/CV/CX" by Thomas Adams - ijabbott - 10-03-2020 11:51 AM (10-02-2020 10:30 PM)Eric Rechlin Wrote: Also, I use a Martin Yale 7000e stack paper cutter for cutting off bindings. It will cut a phone book in half like going through butter with a warm knife. Very clean cuts. Yikes! Sounds a bit destructive. Would a cheap and cheerful book scanner like this DIY example work, do you think? https://www.youtube.com/channel/UCwMsuo69GH2OkeFk8Y9jHmQ/videos RE: HP-41 Book "Programming the HP 41C/CV/CX" by Thomas Adams - Eric Rechlin - 10-03-2020 02:54 PM (10-03-2020 11:51 AM)ijabbott Wrote:(10-02-2020 10:30 PM)Eric Rechlin Wrote: Also, I use a Martin Yale 7000e stack paper cutter for cutting off bindings. It will cut a phone book in half like going through butter with a warm knife. Very clean cuts. It would work, yes, though with a bit worse scan quality. But the biggest problem with that is it would probably take 100 times as long to do the scan. With my approach, the cut is very clean and precise so the book can be re-bound again, either with a perfect binding (not my preference) or with a spiral binding (much more usable!). I only take off about 2mm. RE: HP-41 Book "Programming the HP 41C/CV/CX" by Thomas Adams - Nate - 10-04-2020 03:48 AM (09-06-2020 10:21 AM)HP67 Wrote: Any interesting side note: I purchased several. They all look unused. One has a similar sticker on the back that I didn't remove. RE: HP-41 Book "Programming the HP 41C/CV/CX" by Thomas Adams - Bill (Smithville NJ) - 10-04-2020 11:27 AM (10-02-2020 10:30 PM)Eric Rechlin Wrote: You should ask permission to post it on the forum! I have used a Fujitsu Scansnap ix500 for several years. It's a real workhorse of a scanner. While I don't have access to a paper cutter, I found that I can take a book to Staples, have them slice off the spine, then I scan it in, and then take it back to Staples to have a spiral binding put back on the book. Costs about $10 total. I end up with a nice spiral bound manual plus a scanned copy. Bill Smithville, NJ RE: HP-41 Book "Programming the HP 41C/CV/CX" by Thomas Adams - Maxdao - 10-05-2020 07:08 PM (10-02-2020 09:03 PM)Allen Wrote: There is a possibility we could have more of Dr. Adams' work to scan in the coming months, so maybe don't buy the updated ThumbDrive/DVD TOO soon?? Do you have a rough idea of when the next version of the DVD will be available please ? RE: HP-41 Book "Programming the HP 41C/CV/CX" by Thomas Adams - HP67 - 12-27-2020 11:56 AM I'm sorry. Checking my HP doc I don't have this book after all. RE: HP-41 Book "Programming the HP 41C/CV/CX" by Thomas Adams - Sylvain Cote - 12-27-2020 04:10 PM (10-05-2020 07:08 PM)Maxdao Wrote:Given that I have received my Version 8 in December 2014, I would not put my hope very high to get a new release anytime soon. (years)(10-02-2020 09:03 PM)Allen Wrote: There is a possibility we could have more of Dr. Adams' work to scan in the coming months, so maybe don't buy the updated ThumbDrive/DVD TOO soon??Do you have a rough idea of when the next version of the DVD will be available please ? RE: HP-41 Book "Programming the HP 41C/CV/CX" by Thomas Adams - telemachos - 12-27-2020 06:35 PM Abebooks is a meta-site: it offers individual booksellers a place to list books for sale. Used.addall.com, on the other hand, could be called a meta-meta-site: it searches the listings compiled by Abebooks and other meta-sites, among which are Amazon and Biblio. Used.addall.com does not find any copies of Thomas Adams's HP-41 book. But consider these results of searches for Adams's "Mastering the HP 48G-Gx": Abebooks finds two sellers of the book, and Used.addall.com has 12 hits (two of which are the Abebooks hits). The 10 other hits are listings from Alibris, Amazon, AmazonCA, AmazonDE, AmazonFR, Biblio, and Biblio.co.UK. Listings on Used.addall.com are not as thorough, nor as beautiful, as those on Abebooks. But if I want to find a book, my go-to site is always Used.addall.com. RE: HP-41 Book "Programming the HP 41C/CV/CX" by Thomas Adams - Allen - 12-27-2020 07:50 PM (10-02-2020 03:04 AM)bbergman Wrote: The eBay item says in the description that the book was scanned for the use of the Museum. I wonder if it actually made it to the archives? Greetings! I sent to Dave promptly, as mentioned here and elsewhere. Documents I've sent since 2015, which are not included in the Museum Collection DVD V 8 as of 12/27/2020 for some reason or another:
I don't know when/how dave updates the document list, if you are eager to see amendments processed and available, perhaps we could start a separate thread to discuss as a community? NOTE: Version 8.00, Released November 2014 is now over 6 years old, I don't want to get your hopes up. |
