(41CV) Coastal Engineering Technical Aid No. 83-9 (3) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP-41C Software Library (/forum-11.html) +--- Thread: (41CV) Coastal Engineering Technical Aid No. 83-9 (3) (/thread-15571.html) |
(41CV) Coastal Engineering Technical Aid No. 83-9 (3) - SlideRule - 09-12-2020 12:05 AM An extract from Coastal Engineering Technical Aid No. 83-9, Hand-Held Calculator Algorithms for Coastal Engineering; Report 3, USA-CoE, Coastal Engineering Research Center, CETA 83-9, December 1983, 29 pages " ABSTRACT This is the third in a series of reports providing handheld calculator algorithms for use in coastal engineering. The first and second reports in this series were published as Coastal Engineering Technical Aids (CETA's) and are available from the U.S. Army Engineer Waterways Experiment Station Tech- nical Report Distribution Center, Vicksburg, Miss. Of these, CETA 82-1 pre- sents a set of six algorithms for programs useful in performing certain wave transformation and wave generation calculations with both the Texas Instru- ments TI-59 (Algebraic Operating System (AOS) notation) and the Hewlett- Packard HP-67 (Reverse Polish Notation (RPN)); CETA 82-4 presents the same six algorithms for use on the HP-41CV (RPN). The present report provides algorithms for three calculator programs that forecast gravity water waves in deep and shallow water. Two programs use the Joint North Sea Wave Project (JONSWAP) shallow- and deepwater wave fore- casting equations as presented in the Coastal Engineering Research Center's Shore Protection Manual (revised edition to be published in 1984). The third program uses equations to predict a depth-limited significant wave height. The programs are intended for use with the HP-41CV. … CONTENTS … PART II: PROGRAMS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 103R-41CV-REV: JONSWAP Shallow-Waler Wave Forecasting Equations, Revised . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 106R-41CV: JONSWAP Deepwater Wave Forecasting Equations . . . . . 11 107R-41CV: Depth-Limited SignificanL Wave Height . . . . . . . . . . . . 16 … " BEST! SlideRule |
