Faulty Register RS5 in HP-97 - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Faulty Register RS5 in HP-97 (/thread-15618.html) |
Faulty Register RS5 in HP-97 - Karl-Ludwig Butte - 09-22-2020 02:30 PM Dear All, I just executed the "Diagnostic Program" from the standard pac on my HP-97 and it showed error code 15, meaning that RS5 is defect. I further investigated and found out, that storing a value in Reg 5, f P<->S, f P<->S, RCL 5 shows either 0 or sometimes -0,66 but never 5 which was stored in the first place. Does this mean that explicitely RS5 is defect or is another reason possible? Have any of you ever had a similar case and could it be repaired? Any hint will be very much appreciated. Thank you very much in advance. Best regards Karl RE: Faulty Register RS5 in HP-97 - teenix - 09-23-2020 08:53 AM It would appear that the part of the RAM chip (Probably in ROM 6) that stores/recalls RS5 is faulty. You could also verify this by Code:
The display should show 5. cheers Tony RE: Faulty Register RS5 in HP-97 - Karl-Ludwig Butte - 09-23-2020 09:43 AM Hello Tony, thank you very much for your reply. I entered the code sequence you described and got 5 as result just as you described. I then repeated my original Test 5 STO 5, f P<->S, f P<->S, RCL 5 and received the correct result 5, too. It seems that the malfunction disappeared. The I retested the diagnostic program from the standard pack again which passed without errors, too. Everything works fine again. I don't know how and why but I'm not complaining ;-) Thanks again. Best regards Karl |
