HP-41 Halfnut constrast setting - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP-41 Halfnut constrast setting (/thread-15829.html) |
HP-41 Halfnut constrast setting - hth - 11-02-2020 05:49 PM I know there are functions around to fiddle with this nibble, I am wrote some myself long time ago. What I wonder is, what is the preferred way of doing it today? Having functions or a mode/means to press plus or minus key to adjust it, what is around? RE: HP-41 Halfnut constrast setting - CY-CL - 11-02-2020 06:02 PM In the HEPAX module is a funtion called CTRAST to setup the contrast. RE: HP-41 Halfnut constrast setting - Garth Wilson - 11-02-2020 07:31 PM I've never had any reason to change it; but is there a way to do so with synthetic programming, or with something like the ZENROM's RAM editor? RE: HP-41 Halfnut constrast setting - Didier Lachieze - 11-03-2020 08:39 AM (11-02-2020 07:31 PM)Garth Wilson Wrote: is there a way to do so with synthetic programming, or with something like the ZENROM's RAM editor? I don't think so, on my 41CX halfnut I found that the contrast was a bit low so I adjusted it with the functions from the Sandmath module which were initially published in HPX V1N6p8 by Michael Katz:
RE: HP-41 Halfnut constrast setting - Ángel Martin - 11-03-2020 01:22 PM with value in X: (between 0 and 15) Code: 094 "T" RE: HP-41 Halfnut constrast setting - dmh - 04-13-2022 07:27 AM If you're interested in seeing the different halfnut contrast settings before investing the time and effort to get a program working to set it, I captured all the settings below. |
