test post - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Test forum (/forum-18.html) +--- Thread: test post (/thread-15863.html) |
test post - ytterligare - 11-08-2020 10:39 PM ABCD, why my previous post did not....post ? RE: test post - Gene - 11-08-2020 11:22 PM All new members are moderated until they have posted X times to avoid spammers clogging up the forum. RE: test post - David Hayden - 12-08-2020 04:35 PM (11-08-2020 11:22 PM)Gene Wrote: All new members are moderated until they have posted X times to avoid spammers clogging up the forum. Gene, I imagine that you get quite a few spammers. Thank you (and the other moderators) for doing this invisible service. RE: test post - grsbanks - 12-08-2020 05:22 PM This forum has been around much longer than the SwissMicros forum and has much more exposure, and yet over there I had to kick out between 30 and 40 junk sign-ups every day (from certain IP addresses or from well known VPN services) until I started blocking access from those parts of the internet. I can't begin to imagine what it must be like here! RE: test post - Massimo Gnerucci - 12-08-2020 06:43 PM (12-08-2020 05:22 PM)grsbanks Wrote: or from well known VPN services Noticed this when trying to connect to SM forum while already connected to my VPN (Your IP was banned, or something along the lines). Could not understand at first. Will try double VPN redirection! ;) RE: test post - grsbanks - 12-08-2020 09:12 PM (12-08-2020 06:43 PM)Massimo Gnerucci Wrote: Noticed this when trying to connect to SM forum while already connected to my VPN (Your IP was banned, or something along the lines). Could not understand at first. If you will be coming in from a specific IP address that you alone use, I can whitelist that. Spammers absolutely love using a VPN because it covers their tracks. RE: test post - Massimo Gnerucci - 12-08-2020 09:21 PM (12-08-2020 09:12 PM)grsbanks Wrote:(12-08-2020 06:43 PM)Massimo Gnerucci Wrote: Noticed this when trying to connect to SM forum while already connected to my VPN (Your IP was banned, or something along the lines). Could not understand at first. Don't remember exactly from what VPN location I was connected. Made some attempts a couple of hours ago: no issue this time. Possibly the external IP changed since last time. Anyway this is not a problem: I usually connect from my home IP. RE: test post - 1 - Peter Henderson - 04-11-2021 03:42 AM Testing a reply RE: test post - Over_score - 04-20-2021 09:54 AM Testing another reply RE: test post - jebem - 02-26-2022 07:55 PM refreshing my subscription RE: test post - jebem - 02-28-2023 03:53 PM refreshing my login RE: test post - rprosperi - 03-01-2023 03:36 AM (02-28-2023 03:53 PM)jebem Wrote: refreshing my login Welcome back!! RE: test post - Thomas Klemm - 03-01-2023 08:10 PM (03-01-2023 03:36 AM)rprosperi Wrote:(02-28-2023 03:53 PM)jebem Wrote: refreshing my login We were just a bit worried: (12-08-2022 03:35 AM)rprosperi Wrote:(12-07-2022 07:40 PM)Jlouis Wrote: By the way, I'm missing jebem (Jose Mesquita) always good posts. We don't want to lose you to the RadioMuseum. RE: test post - Mike S - 03-28-2023 09:03 AM testing again RE: test post - HPleak - 08-18-2023 08:28 AM testing |
