(HP-67/97) OSCAR the ham radio satellites - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP-65/67/97 Software Library (/forum-12.html) +--- Thread: (HP-67/97) OSCAR the ham radio satellites (/thread-15966.html) |
(HP-67/97) OSCAR the ham radio satellites - SlideRule - 11-26-2020 04:43 PM An extract from OSCAR the ham radio satellites, Chapter 6 - Satellite Tracking Simplified, 1e DEC 1979, pgs. 69-87 "… CALCULATOR PROGRAMS FOR TRACKING OSCAR While the satellite orbital calculations and tracking aids already already mentioned are quite sufficient for OSCAR operations, many amateurs want to use their electronic calculators. With this in mind here are some amateur-developed satellite calculation methods which can run on pocket calculators. Since all the work associated with these programs has been performed, you can merely load your calculator directly with information from the following pages and you're set. … … the circular orbit program … elliptical orbit program … will work on the Hewlett-Packard HP67 or HP97 calculator … … Table 6-3 Circular Orbit Program (pgs. 73-76) … Table 6-7 Elliptical Orbit Program (pgs. 81-85) …" BEST! SlideRule |
