Microbaud MLDL anyone .. ? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Microbaud MLDL anyone .. ? (/thread-15994.html) |
Microbaud MLDL anyone .. ? - ThomasF - 12-02-2020 07:01 AM Hi, Years ago (many) I bought a MLDL box, developed M-Code etc for the 41 and even modified it by adding more memory to it. ![]() I recently found the box amongst my other old 41 stuff, but I can't get it to work anymore. The PCB itself is marked "(c) Microbaud Developments Machine Language Interface '82 HP-41", and on the backside it says "(c) 1982 Microbaud Developments", "ML I VER. A" and "Made in Aust", and if I remember correctly I bought it directly from Australia back then. This MLDL is probably very close to the original by Lynn Wilkins, so I might be able to reverse-engineer the PCB - but is there anyone out there who might have a copy of the schematics for this version of MLDL? Googeling has not given me any clues about the card (apart from a similar question on this forum back in 2004 with no responses), but any scans of some schematichs might help! Best regards, Thomas RE: Microbaud MLDL anyone .. ? - Sylvain Cote - 12-02-2020 12:32 PM Lynn A. Wilkins MLDL article and schemas was published in PPC Journal V9 N3 P27@35. You can get the journals from Jake Schwartz (PAHHC) at http://www.pahhc.org/ppccdrom.htm RE: Microbaud MLDL anyone .. ? - ThomasF - 12-02-2020 01:15 PM Hi Sylvain! Yes, still got all PPC journals so getting schematics for the original Wilkins MLDL is no problem ![]() I was hopeing someone still got the documentation/schematics for this Microbaud MLDL board. But, I'll probably have to go into "reverse engineer" mode and redraw it from scratch using Wilkins as a base line - hopefully they are not that different ... ![]() Cheers, Thomas RE: Microbaud MLDL anyone .. ? - Sylvain Cote - 12-02-2020 02:16 PM (12-02-2020 07:01 AM)ThomasF Wrote: but is there anyone out there who might have a copy of the schematics for this version of MLDL? (12-02-2020 01:15 PM)ThomasF Wrote: I was hopeing someone still got the documentation/schematics for this Microbaud MLDL board.Hello Thomas, Oups! I had not read your initial post correctly, sorry. Sylvain RE: Microbaud MLDL anyone .. ? - ThomasF - 12-08-2020 01:11 PM A bit embarrassing as my search was not good enough. I just found the documents I was looking for where I should have searched in the first place! So now I'm ready to dig into the MLDL-box again ![]() RE: Microbaud MLDL anyone .. ? - KimH - 12-08-2020 01:29 PM I built my MLDL based on an Australian diagram (I have a copy in Pencil from back then) after having waited for them to send me a PCB (I had paid 50 AU$ for it, but it never arrived). Maybe they were connected with MicroBaud. Would you be OK to share what you got, curious ![]() (12-08-2020 01:11 PM)ThomasF Wrote: A bit embarrassing as my search was not good enough. RE: Microbaud MLDL anyone .. ? - rprosperi - 12-08-2020 01:29 PM (12-08-2020 01:11 PM)ThomasF Wrote: A bit embarrassing as my search was not good enough. Worry not, it's not only you. I often find misplaced things in the exact same spot! There can be no doubt that some of these things quietly migrate when we're not looking... ![]() RE: Microbaud MLDL anyone .. ? - ThomasF - 12-08-2020 02:27 PM (12-08-2020 01:29 PM)KimH Wrote: I built my MLDL based on an Australian diagram (I have a copy in Pencil from back then) after having waited for them to send me a PCB (I had paid 50 AU$ for it, but it never arrived). Hi Kim! Search on TOS with "Microbaud" and you will find what I was looking for ... ![]() /Thomas RE: Microbaud MLDL anyone .. ? - KimH - 12-08-2020 03:08 PM (12-08-2020 02:27 PM)ThomasF Wrote:(12-08-2020 01:29 PM)KimH Wrote: I built my MLDL based on an Australian diagram (I have a copy in Pencil from back then) after having waited for them to send me a PCB (I had paid 50 AU$ for it, but it never arrived). Thanks Thomas, that was exactly what I had in pencil. Built mine with "Fädel" a German version of WireWrap. Now here is some fun for a couple of hours reading and taking a walk on Memory Lane /KimH RE: Microbaud MLDL anyone .. ? - ThomasF - 12-27-2020 05:14 PM YES!! 35+ years later I picked up my modified MLDL-box, and with some new soldering, debugging and rewireing I managed to bring it back to life again! All RAM is still working! Alas - there is no PC-connection - and have left my eprom-burner somewhere a long time ago - but still! First step will be to write some small functions and refresh my MCode skills ... ![]() At least this year ends slighly positive ... ![]() |
