How to calculate the binomial in the HP30b? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: How to calculate the binomial in the HP30b? (/thread-16093.html) |
How to calculate the binomial in the HP30b? - FabioBrasil - 12-30-2020 08:07 PM Hi I purchased an HP30b financial calculator and am very satisfied. I used an HP12c for five months, but I didn't get used to the layout of the keys (very polluted look!). I found the HP30b more complete !. I know that the HP30b does the binomial calculation (Math> Probability> Binomial), but I don't know how to enter the data. I made a program for this, but I know that the calculator does it automatically. How do I enter the data for the binomial calculation? for example: n = 10 k = 1 p = 0.1 I know the answer is 0.3874 (38,74%) How do I calculate directly with the HP30b? Thanks! RE: How to calculate the binomial in the HP30b? - Gamo - 12-31-2020 11:25 AM I don't have the HP30b but I did post on about calculate the Binomial for the HP-12C since you also got the 12C so you might try this out first and see if it is harder or easier to do between 30b and 12c https://www.hpmuseum.org/forum/archive/index.php?thread-11264.html for example: n = 10 k = 1 p = 0.1 I know the answer is 0.3874 (38,74%) Once enter this program to run. [f] 4 for Fix 4 10 [ENTER] 1 [ENTER] .1 [R/S] display 0.3874 Gamo RE: How to calculate the binomial in the HP30b? - Stevetuc - 12-31-2020 11:50 AM (12-30-2020 08:07 PM)FabioBrasil Wrote: Hi From the 30b user guide page 23: HP30b userguide Binomial Functions The binomial function calculates the probability of having up to k successes out of n throws, when the probability of success is p. Enter n and p each followed by = and type k and navigate to the binomial function in the math menu. RE: How to calculate the binomial in the HP30b? - Gene - 12-31-2020 01:03 PM #31 in this list. Download and work through it. HP-30b learning modules RE: How to calculate the binomial in the HP30b? - ijabbott - 12-31-2020 01:07 PM (12-30-2020 08:07 PM)FabioBrasil Wrote: Hi The answer 0.3874 is the probability mass function (PMF) value, which is the probabilty of exactly k successes. The HP-30b doesn't have a built-in function for that. It has a built-in function for the cumulative distribution function (CDF) value, which is the probability of k or fewer successes. The answer for that is 0.7361 (73.61%). Well, you could use the built-in binomial CDF to calculate for n=10, p=0.1, k=0, store that in a memory, calculate for n=10, p=0.1, k=1, and subtract the previously stored value, but that is cumbersome and error prone. It would be easier to use the PMF formula you already know. RE: Como calcular o binĂ´mio no HP30b? - FabioBrasil - 12-31-2020 07:08 PM I thank everyone! I was able to get the answer with the Learning Module suggested by the moderator Genes. Through this material, I saw that the binomial in the HP30b is an embedded function calculated for the value of the cumulative distribution function (CDF). Unlike HP Prime that does it directly! I did what Ijabbott suggested and everything went well. Every day I like this calculator more. Thank you and have a great new year! |
