Processing lists on the 50G - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Processing lists on the 50G (/thread-16104.html) |
Processing lists on the 50G - EngineerX - 01-01-2021 04:42 AM Hello everyone, Happy new year. Let me ask you a question about lists on the 50g: How would one go about processing a number of lists such as these ones: {1 2 3} - might label it x {0 1 2} - might label it y Now, what you be the procedure to make another list whose elements are a function f(x,y) such as (1+1/x)*y? Thank you in advance. Edit: I am reading the manual (48, not 49). It shows how to do it with one list and using a program, which would be ideal. The problem is how to make the program process two or more lists at once. RE: Processing lists on the 50G - Joe Horn - 01-01-2021 04:58 AM (01-01-2021 04:42 AM)EngineerX Wrote: Hello everyone, Happy new year. List processing has been built into RPL starting with the 48G series. If Y is on level 2 of the stack, and X is on level 1 (as their names imply), then: INV 1 ADD * will return the result you're looking for. You might want to do SIMPLIFY on the resulting list. RE: Processing lists on the 50G - EngineerX - 01-01-2021 05:02 AM (01-01-2021 04:58 AM)Joe Horn Wrote:(01-01-2021 04:42 AM)EngineerX Wrote: Hello everyone, Happy new year. The magician J. Horn. Thank you. |
