Install CK on New iMac with Big Sur - Printable Version
+--- Thread: Install CK on New iMac with Big Sur (/thread-16293.html)
Install CK on New iMac with Big Sur - BERNARD MICHAUD - 02-07-2021 08:11 PM
I notice on the web someone who had a problem installing the CK 2020 1 16 (assuming its the latest version) onto a Mac Catalina. I had the same problem on a iMac Big Sur when the CK was downloaded from web and attempted to install it. It was rejected by Apple who could not check the CK software for MALICIOUS content. So I instinctively inserted an SD Card in my older Macbook Pro and made a direct copy/past of the CKApp from the Application folder to the Sd Card. On the iMac Big Sur I copy/paste the CK app into the Application folder directly and it works fine. There was only one incident where the CK App crashes if you turn off the Prime calculator prior to closing the CK app.
BM
