Casio fx-991EX Matrix Calculation - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: Casio fx-991EX Matrix Calculation (/thread-16294.html) |
Casio fx-991EX Matrix Calculation - Gamo - 02-08-2021 05:35 AM Casio fx-991EX manual didn't give example on the use case for the Inverse of the Matrix while HP-15C User's Handbook gave the example problem for the Inverse Matrix and Multiplication of Matrix to use for the Linear Equation of Unkonws Varibles. I'll use 15C User's Handbook Example on Page 156 "Title Soving the Equation AX=B" AX=B equation can be changed to X = A^-1 x B Example Matrix Equation: On page 157 Here is the steps on how to enter "Matrix Calculations" using Casio fx-991EX with Matrix Mode [MENU] [4] // Matrix Mode // [1] // Matrix A // [2] [2] // Set Matrix A to 2x2 // [1] [=] [1] [=] [.24] [=] [.86] [=] [OPTN] [1] [2] // Define Matrix and Matrix B // [2] [3] // Set Matrix B to 2x3 [274] [=] [233] [=] [331] [=] [120.32] [=] [112.96] [=] [151.36] [=] [OPTN] [3] // Matrix Calculation // [OPTN] [3] // Seclect Mat A // Screen Display MatA enter [X^-1] [x] [OPTN] [4] Screen Display MatA^-1 x MatB press [=] Screen Shown Answer: MatAns= 186, 141, 215, 88, 92 and 116 Remark: A system of Linear Equation can be solve by using the [MENU] mode A seclection #1: Simul Equation for the restriction that constant matrix and solution matrix each had one column. While the example shown above is for a constant matrix and solution matrix with more than one column. Gamo 2/2021 RE: Casio fx-991EX Matrix Calculation - BINUBALL - 03-16-2021 01:06 AM Unfortunately, In 570EX manual 27 page. There are inverse matrix example. but well done! |
