Plus42 algebraic expressions update - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: Plus42 algebraic expressions update (/thread-16372.html) |
RE: Plus42 algebraic expressions update - Vincent Weber - 02-26-2021 09:10 AM Thanks Thomas, progressing well, and general comparisons are a nice addition too ! Maybe something should be done to access the parenthesis. On the 27S/17BII you have dedicated keys, but not on the 42S, so you have to dig several layers of alpha menu to find them - not so practical when you just want to close SIN(X ! I'm sure you'll also find a way to put INTEG in equations Cheers RE: Plus42 algebraic expressions update - Thomas Okken - 02-26-2021 11:29 AM (02-26-2021 08:21 AM)SammysHP Wrote: I would expect that the same resolution applies as for multiple identical labels. Still unclear whether equations or programs should get a higher priority... I'd say programs. Optimize the most common use case. (02-26-2021 09:01 AM)Werner Wrote:(02-26-2021 06:37 AM)Thomas Okken Wrote: it includes the generalized comparison functions: X=? param, 0=? param, etc.What is the Y^X fix? (EDIT ah of course the sign of complex zero, silly me) Yes. (02-26-2021 09:10 AM)Vincent Weber Wrote: Maybe something should be done to access the parenthesis. On the 27S/17BII you have dedicated keys, but not on the 42S, so you have to dig several layers of alpha menu to find them - not so practical when you just want to close SIN(X ! Yes, the parentheses should be easier to reach. I could put them on [X⇄Y] and [+/-], or [Shift] [▲] and [Shift] [▼]... (Not [STO] and [RCL], I think those should insert L( and G(.) And sure, I could make SOLVE and INTEG callable from equations... But I can already see the emails from users who are going to discover that SOLVE and INTEG don't nest! RE: Plus42 algebraic expressions update - Thomas Okken - 02-26-2021 11:31 AM Since we're on a new page, here's the download link again: https://thomasokken.com/free42/download/test/ RE: Plus42 algebraic expressions update - Vincent Weber - 02-26-2021 11:43 AM Thanks Thomas. I thought INTEG and SOLVE did nest since the HP-34C ? Cheers RE: Plus42 algebraic expressions update - Paul Dale - 02-26-2021 12:07 PM The 34C allows solve to call integrate (and the reverse) but not solve to call solve or integrate call integrate. Pauli RE: Plus42 algebraic expressions update - Thomas Okken - 02-26-2021 12:13 PM The HP-42S and Free42 do allow SOLVE and INTEG to call each other, but not themselves. RE: Plus42 algebraic expressions update - Werner - 02-26-2021 12:15 PM You can SOLVE an integral or INTEG a solved function; you can't nest INTEGs to calculate a double integral. eg. find a zero of the Bessel function J0(x) = 1/PI * INT(0,PI,COS(x*SIN(t),t) 1.define the integrand Code: LBL "J0i" 2.define the function Code: LBL "J0" 3.Invoke the interactive SOLVER, choose J0 etc. Cheers, Werner RE: Plus42 algebraic expressions update - Vincent Weber - 02-26-2021 12:30 PM Thanks, yes, that's what I had in mind. I thought by "nested" you also meant calling each other Cheers RE: Plus42 algebraic expressions update - Thomas Okken - 02-26-2021 01:56 PM Question for people more familiar with the 17B/27S expressions: Do the square brackets have any special meaning? I would like to use [ and ] for list and array indexing, but also remain compatible with the original calculators as much as is reasonably possible. RE: Plus42 algebraic expressions update - Vincent Weber - 02-26-2021 02:24 PM AFAIK the square brackets are unused in the 27S/17BII solver. Everything follows the FUNCTION(param1:param2:...paramn) logic. Cheers RE: Plus42 algebraic expressions update - Thomas Okken - 02-26-2021 02:50 PM Great, thanks! RE: Plus42 algebraic expressions update - Thomas Okken - 02-26-2021 03:53 PM 10:46 AM EST / 15:46 UTC -- Uploaded new builds
I still have to add support for CATALOG, but apart from that, I think the equation editor is pretty much done. Things I noticed and fixed after creating these builds:
RE: Plus42 algebraic expressions update - Vincent Weber - 02-26-2021 05:43 PM One thing that may help: on this page you have all the solver functions from the 19B (the most complete set, with the highest number of financial functions): http://www.finseth.com/hpdata/hp19b.php Cheers RE: Plus42 algebraic expressions update - Thomas Okken - 02-26-2021 09:28 PM 4:25 PM EST / 21:25 UTC -- New builds, fixing incorrect encoding of the new comparison operators in raw files and in the state file, causing them to get mangled. Also fixed handling of direct-mapped 1/X, Y^X, and X^2 in the equation editor (affects the DM42 skin, for example), and added mapping of : to Shift ÷. RE: Plus42 algebraic expressions update - Vincent Weber - 02-26-2021 09:34 PM Talking about top row functions, maybe it would be nice that the sigma sign translates not only into sigma sign, but add an opening parenthesis, as the sigma (sum) function always requires one to enter its parameters... RE: Plus42 algebraic expressions update - Thomas Okken - 02-26-2021 11:31 PM (02-26-2021 05:43 PM)Vincent Weber Wrote: One thing that may help: on this page you have all the solver functions from the 19B (the most complete set, with the highest number of financial functions): Noted. Thanks! (02-26-2021 09:34 PM)Vincent Weber Wrote: Talking about top row functions, maybe it would be nice that the sigma sign translates not only into sigma sign, but add an opening parenthesis, as the sigma (sum) function always requires one to enter its parameters... Indeed. Done! I'm also adding a mapping from R/S to the equals sign. RE: Plus42 algebraic expressions update - Vincent Weber - 02-27-2021 12:11 PM Great ! Last thing may be a shortcut to IF(, as conditionals are important Cheers RE: Plus42 algebraic expressions update - Thomas Okken - 02-28-2021 12:00 AM 6:59 PM EST / 23:59 UTC -- New build, lots of small fixes having to do with menu behavior, and with skins with Direct Command Mapping. RE: Plus42 algebraic expressions update - Thomas Okken - 02-28-2021 03:52 AM (02-27-2021 12:11 PM)Vincent Weber Wrote: Last thing may be a shortcut to IF(, as conditionals are important Noted! I'll put it on my list. I think the equation editor is OK now, it's complete in terms of functionality and seems robust, apart from Copy & Paste and some error handling for low-memory situations. I'm starting on the equation parser tomorrow, that's when it starts to get interesting. UPDATE 10:49 PM EST / 3:49 UTC -- Copy & Paste implemented in the equation editor. Also, eliminated the 256-character string length limit in Paste. RE: Plus42 algebraic expressions update - Vincent Weber - 02-28-2021 08:49 AM Thanks Thomas ! This is going to be terrific, the best of 42S/41CX/27S features, without altering the 42S look and feel... Just one funny thing, it is great to be able to access the catalog from the equation editor, but this is the old catalog, not the new one with extended functions organized in groups ? Why ? Cheers |
