(PC-12xx~14xx) qthsh Tanh-Sinh quadrature - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature (/thread-16549.html) |
RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - robve - 04-17-2021 01:51 PM (04-17-2021 12:03 AM)Albert Chan Wrote: The plot showed a nice bell-shaped curve, easy to get area, simply by summing squares. Rather than doing that, I think we can do better to quickly estimate an optimal d using a geometric sequence of points. I ran a few tests with this change to 'quad' for Exp-Sinh: Code: else if (isfinite(a)) { Note what happens to 'diff' for these integrands: exp(-.2*x) on [0,inf) d~45 is good exp(-.1*x) on [0,inf) d~100 is good exp(-.01*x) on [0,inf) d~700 is good exp(-.001*x) on [0,inf) d~9000 is good 1/(x*x) on [1,inf) d~1 is good 1/(1+x*x) on [0,inf) d~1 is good log(1+(x*x))/(x*x) on [0,inf] d~1 is good (x*x*x)/(exp(x)-1) on [0,inf) d~7 is best d~8 is good x/sinh(x) on [0,inf) d~9 is best d~8 is good (x*x)/sqrt(exp(x)-1) on [0,inf) d~17 is best d~16 is good pow(x,7)*exp(-x) on [0,inf) d~25 is best and d~32 is good exp(-sqrt(x)) on [0,inf) d~81 is best and d~64 is good exp(-x)*(x*x*x) on [0,inf) d~28 is good exp(-x)*pow(x,5) on [0,inf) d~50 is good Note the \( 2^i \) value when the diff sign changes, if it changes. Periodic functions switch signs multiple times, these are not great to integrate with Exp-Sinh anyway e.g. sin(x)/(x*x) on [0,inf). The idea of using geometric sequences to determine d aligns with the Exp-Sinh rule. This method is not perfect yet and certainly needs some tweaking. - Rob Edit: I checked 208 Exp-Sinh integrals from the benchmarks and they all show that this conceptually works. I've added some more interesting cases to the list. RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - Albert Chan - 04-17-2021 11:45 PM (04-17-2021 01:51 PM)robve Wrote: printf("%d diff=%g\n", 1 << i, f(a + d/v)/v - f(a + v*d)*v); There may be a flaw with this ... Example, we know exp(-0.01*x) on [0,inf], d ~ 700 is good But, we can rewrite the integrand as exp(-0.01/x)/x^2, that has optimal d ~ 1/700 With sign checking method, both will suggest optimal d ~ 700. lua> Q = require 'quad' lua> f = function(x) return exp(-0.01*x) end lua> g = function(x) return exp(-0.01/x)/(x*x) end lua> Q.quad(Q.count(f), 0, huge, 700), Q.n 100 71 lua> Q.quad(Q.count(g), 0, huge, 1/700), Q.n 100 71 If we build g(x) = f(1/x)/x^2, both would use the *same* points, with orders swapped. (points might have rounding errors with 1/x, but otherwise equivalent.) The formula is just simple substitution, x = 1/y, dx = -dy/y^2 \(\displaystyle \int_a^∞ f(x)\,dx = \int_0^∞ f(x+a)\,dx = \int_0^∞ {f(1/y+a) \over y^2} dy\) RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - robve - 04-18-2021 01:30 AM (04-17-2021 11:45 PM)Albert Chan Wrote: There may be a flaw with this ... Not so fast. In your example the left side's magnitude f(a+d/v)/v is larger than f(a+d*v)*v which means that the sign changes for a different reason. In my test this shows that d should be small (because the test also takes the magnitudes of the difference into account). So your example is not a counter example of my earlier post on why this might work. Furthermore, as you will notice, the sign change is not always the exact place for an optimal d, but close. The magnitude change is a critical indicator (and more reliable) in the neighborhood of the sign change. So far it works every time. I was surprised that when I discovered this that for all integrals of the 208 the sign change suggests there is a solid predictor based on this that can be perfected with some tweaking. - Rob RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - robve - 04-18-2021 01:42 AM (04-18-2021 01:30 AM)robve Wrote: In your example the left side's magnitude f(a+d/v)/v is larger than f(a+d*v)*v which means that the sign changes for a different reason. In my test this shows that d should be small (because the test also takes the magnitudes of the difference into account). So your example is not a counter example of my earlier post on why this might work. Here are the numbers. For your example exp(-0.01/x)/x^2 the change is not due to the right side's magnitude, but the left side: d diff (left-right) 2 diff=2.92578 (3.92079 - 0.995012) 4 diff=14.3751 (15.3726 - 0.997503) 8 diff=58.0807 (59.0794 - 0.998751) 16 diff=217.149 (218.149 - 0.999375) 32 diff=742.577 (743.577 - 0.999688) 64 diff=2158.79 (2159.79 - 0.999844) 128 diff=4554.36 (4555.36 - 0.999922) 256 diff=5065.24 (5066.24 - 0.999961) 512 diff=1565.58 (1566.58 - 0.99998) 1024 diff=36.4476 (37.4476 - 0.99999) 2048 diff=-0.994646 (0.00534945 - 0.999995) 4096 diff=-0.999998 (2.72909e-11 - 0.999998) 8192 diff=-0.999999 (1.77573e-28 - 0.999999) 16384 diff=-0.999999 (1.87946e-63 - 0.999999) 32768 diff=-1 (5.26361e-134 - 1) 65536 diff=-1 (1.03212e-275 - 1) For exp(-.01*x) the change is due to the right side's magnitude: d diff (left-right) 2 diff=-2.92578 (0.995012 - 3.92079) 4 diff=-14.3751 (0.997503 - 15.3726) 8 diff=-58.0807 (0.998751 - 59.0794) 16 diff=-217.149 (0.999375 - 218.149) 32 diff=-742.577 (0.999688 - 743.577) 64 diff=-2158.79 (0.999844 - 2159.79) 128 diff=-4554.36 (0.999922 - 4555.36) 256 diff=-5065.24 (0.999961 - 5066.24) 512 diff=-1565.58 (0.99998 - 1566.58) 1024 diff=-36.4476 (0.99999 - 37.4476) 2048 diff=0.994646 (0.999995 - 0.00534945) 4096 diff=0.999998 (0.999998 - 2.72909e-11) 8192 diff=0.999999 (0.999999 - 1.77573e-28) 16384 diff=0.999999 (0.999999 - 1.87946e-63) 32768 diff=1 (1 - 5.26361e-134) 65536 diff=1 (1 - 1.03212e-275) Part of tweaking the test to get an optimal d is to observe the cliff: there is a sharp drop in magnitude in the right part, from 1566.58 to 37.4476 while the left side is still smooth, followed by a sign change. This suggests an optimal d is somewhere near 512-1024. Edit: I just now realized I had changed the test earlier today with respect to the magnitude check included in the test as a filter. I had not published this change or said anything about it. To produce the numbers shown above: Code: else if (isfinite(a)) { Note that this scales the left fl and right fr by r just to make the value's magnitudes comparable to display, otherwise this is unnecessary. This is not the final version, since this can be further improved. - Rob RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - robve - 04-18-2021 12:56 PM (04-17-2021 11:45 PM)Albert Chan Wrote: With sign checking method, both will suggest optimal d ~ 700. Edit: I've updated the document with an improved version of the predictor (shown below) and an explanation how it works. The following update sets d=1/700 for this case, so d is now either increased or decreased towards an optimum: Code: else if (isfinite(a)) { This is a rough predictor that could be further improved. But this predictor is already reasonably effective to increase or decrease d in order to reduce the number of points evaluated by Exp-Sinh. The predictor evaluates points too, but quits when an optimal d is found. There are ways to reduce this overhead, e.g. taking larger steps for d and perhaps followed by a second refinement step to adjust d. With the simple predictor I've tested 208 integrals on [a,+inf) in the zip file with eps=1e-9: 29 are improved with 61 fewer points on average to integrate each of those. - Rob RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - Albert Chan - 04-19-2021 10:16 PM (04-18-2021 12:56 PM)robve Wrote: There is one bad case exp(-3*(x*x)-4/(x*x)) with 228 more points. The predictor pushes too hard on this one where the diff is close to zero already at the begin of the search, meaning there is no need to search for d in this case.Note: this quote was removed, but it is instructive to see why it failed ... Close to zero at the beginning of search is expected, for any f(x). When v=1, f(v)*v - f(1/v)/v = f(1) - f(1) = 0 This is just the trivial solution, and cannot be used to predict d = 1. To simplify, let v = e^t, instead of v = 2^t: \(\displaystyle \int_0^∞ f(x)\,dx = \int_{-∞ }^∞ f(v)·v\,dt = \int_0^∞ \left[f(v)·v + f({1\over v})·{1\over v}\right]\,dt \) Except for v=1, if last 2 term are same size, we assumed both will be tiny. This should covered most of the (likely bell-shaped) area, thus can estimate optimal d. --- Back to why f(x) = exp(-3*(x*x)-4/(x*x)) failed sign change search. f(v)*v = f(1/v)/v, where v = e^t Take log both side: -3*exp(2t) - 4*exp(-2t) + t = -3*exp(-2t) - 4*exp(2t) - t 2t + exp(2t) - exp(-2t) = 0 t + sinh(t) = 0 On the left, both terms are increasing function, only solution is t=0. Thus, except for the trivial v=1, there is no solution. And, there are many more bad cases, say, g(x) = exp(-m*x), m ≥ 1 g(v)*v = g(1/v)/v Again, substitute v=e^t, and take log both side: -m*e^t + t = -m*e^-t - t 2t = m*(e^t - e^-t) t = m * sinh(t) sinh(t) = t + t^3/3! + t^5/5! + ... sinh(t)/t = 1 + t^2/3! + t^4/5! + ... ≥ 1 Removed trivial solution, (t = sinh(t) ⇒ t = 0), we have m < 1 --- Perhaps estimate of d based on peak of f(v)*v is safer ? (there is always a peak, unless integral diverges) f(x) = exp(-3*(x*x)-4/(x*x)) Searching for peak of f(v)*v (we can also do numerically): diff(f(v)*v, v) = 0 f(v) + v*f'(v) = 0 f(v) + v*f(v)*(-6v + 8/v^3) = 0 1 - 6v^2 + 8/v^2 = 0 6v^4 - v^2 - 8 = 0 // assumed v ≠ 0 v^2 = (1+√193)/12 // we throw away the negative root, v^2 > 0 v = √((1+√193)/12) ≈ 1.114 // again, throw away negative root, v=e^t > 0 lua> Q = require 'quad' lua> f = function(x) x=x*x; return exp(-3*x-4/x) end lua> Q.quad(Q.count(f), 0, huge, 1.114) 0.0005013071292635826 1.4667498799376226e-010 lua> Q.n 41 Same treatment for g(x) = exp(-m*x): diff(g(v)*v, v) = 0 g(v)*1 + (g(v)*-m)*v = 0 1 - m*v = 0 v = 1/m -- when g(v)*v peaked Peak for d might not be "optimal", but may be good enough. RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - robve - 04-20-2021 02:19 AM (04-19-2021 10:16 PM)Albert Chan Wrote:(04-18-2021 12:56 PM)robve Wrote: There is one bad case exp(-3*(x*x)-4/(x*x)) with 228 more points. The predictor pushes too hard on this one where the diff is close to zero already at the begin of the search, meaning there is no need to search for d in this case.Note: this quote was removed, but it is instructive to see why it failed ... Sharp eye to notice Rather than posting every small change in a new post which is harder and more time consuming to go through, this small change in this post avoids this problematic case for the reason I had already mentioned earlier in that post, the case when the initial diffs are too close to zero. This small update also has another advantage. It allows the search for an optimized d from any initially-specified d instead of d=1. Perhaps this means that the method may have a fixed point that is the optimal d by invoking the predictor repeatedly with improved d and by using smaller steps. Interesting to investigate. (04-19-2021 10:16 PM)Albert Chan Wrote: And, there are many more bad cases, say, g(x) = exp(-m*x), m ≥ 1 Nope. The diff sign does not change for this integrand. And for larger m the search quits early. (04-19-2021 10:16 PM)Albert Chan Wrote: Perhaps estimate of d based on peak of f(v)*v is safer ? I have not found a single counter example yet that does not work with the predictor. I also spent many hours to try various improvements and test them with >208 integrals. I have about a dozen tweaks of the method with mixed results. Not interesting to share. A small change was needed to avoid the "bad" case and others similar to it, which are not difficult to recognize from the valid cases by inspecting the diff h sequence. Note that v (now more appropriately renamed r) should not be too small initially and is r=2 for the \( 2^i \) sequence. I also tried regula falsi to improve d, but unfortunately this does not always help. I also found that larger estimates of d (in the 1000s) tend to overshoot the optimal d. In this case starting with a larger d and then repeating the predictor recursively should improve the estimate closer to optimal. However, keeping things simple pays off, because moving d at least in the right direction helps convergence, even when we don't hit the optimal d, so we don't evaluate more points than necessary (or more than Exp-Sinh needs!). In any case, the geometric sequence of r can be \( 2^i \) or \( e^i \) or another to take larger steps to reduce the number of evaluations. \( 2^i \) is just cheap to compute. (04-19-2021 10:16 PM)Albert Chan Wrote: f(x) = exp(-3*(x*x)-4/(x*x)) I already tried searching for the "cliff" (or point after the peak). I had mentioned the cliff before as relevant. But it is easy to see that the search should continue until the sign changes. Only at the point when the sign changes the following comparison can be safely made to determine the direction that d should move in: if (fabs(fl) < fabs(fr)) d /= r; else d *= r; Doing this at the peak, or right after, fails the method, causing d to move in the wrong direction. However, the peak or cliff can be closer to where the optimal d is located for large d (in the 100s or 1000s), before the sign changes, but this adds more complexity. A simple condition is to check that the diff h is not zero and in that case move r back one step: if (h != 0) r /= 2; If the diff is zero, we are at a reasonably good or optimal r to adjust d. This can happen very early for example 1/(1+(x*x)) and log((1+(x*x))/x)/(1+(x*x)) or late with for example x/sinh(x). For the last integrand we get d=4 (131 points, est.rel.err=2e-11) which improves the accuracy with the same number of points. Applying a regula falsi correction to r (instead of r/=2 see the code) we get d=6.7 (69 points, est.rel.err=6e-10). That's incredible - Rob RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - Albert Chan - 04-20-2021 01:58 PM (04-20-2021 02:19 AM)robve Wrote: I have not found a single counter example yet that does not work with the predictor. Is these two already counter-examples ? Both functions, two sides overlapped, f(v)*v = f(1/v)/v XCas> f1(x) := 1/(1+x*x) XCas> f2(x) := log((1+(x*x))/x)/(1+(x*x)) XCas> simplify([f1(v)*v-f1(1/v)/v, f2(v)*v-f2(1/v)/v]) → [0, 0] In other words, f(e^t)*(e^t) is even function, with respect to t. Technically, there were no sign changes. But, with rounding errors, if lucky, we expected sign changes early on. In other words, closed to whatever starting guess of d was. It just happpened we started with d=1, and d=1 is close to optimal. Now, try g1(x) = f1(x*10), g2(x) = f2(x*10) Since this is simple scaling, we expected both have optimal d ≈ 1/10 I don't think you'd catch a sign change here (except for v=1, useless to predict d) RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - robve - 04-20-2021 07:25 PM (04-20-2021 01:58 PM)Albert Chan Wrote:(04-20-2021 02:19 AM)robve Wrote: I have not found a single counter example yet that does not work with the predictor.Is these two already counter-examples ? I mentioned before that for cases like these the diff h is already zero, or very close to zero. If a sign change happens in that case it is noise/roundoff and should be ignored (as is done in the updated code). These "bad" integrands are easy to filter out without deteriorating the predictions for "good" integrands. Note that the diff h behavior has no peak/cliff with these. A relevant sign change is preceded by some (significant) curve with a peak, that cannot be produced by rounding error noise. Maybe I will be forced to eat my words later if there are many "bad" cases. But so far the hundreds of examples tested don't appear to suggest there is a fundamental problem with this approach, just minor details. Honestly, it is not too difficult to create some problematic "bad" cases that are based on periodic/oscillating functions over [0,∞) for which the diff h has a useless sign change more than once. Take \( \sin(40\pi x)/x^2 \) for example. But doing that is a bit "cheating", because these quadrature methods are known to perform poorly with such type of functions anyway (so it does not matter). IMHO it is more interesting to have a preprocessor to adjust d that works well for the Exp-Sinh integrands that we expect to work well with this quadrature. This should exclude "bad" integrands for which a good value of d cannot be determined to begin with, i.e. Exp-Sinh convergence is always bad with a large residual error. Also,guessing a suboptimal d is not fatal for the "good" integrands. There are several things that are intriguing to look into: - For large estimated d values the predicted d tends to overshoot the optimum non-linearly for large d in the 1000s. I tried a correction method with interpolation, but the results were mixed. My hunch is that the peak+cliff location should be taken into account somehow to adjust for large d (likewise, adjust for tiny d=1/r). - Another way to address this sub-optimality problem for large d is to use a recursive scheme to improve d. We can try a sequence of four values, say r=2,10,100,10000 to detect very roughly where a sign change occurs, then adjust d and try again with some smaller points (say powers of 2) and again with a few points of smaller powers, etc. - The predictor should quit early when d cannot be adjusted (no sign change) by testing the sequence begin/end points first e.g. r=2 and r=10000, to limit this overhead. Checking 1<r<2 is not useful. It only moves d upwards by a fraction which does not help much to improve convergence (downwards by a fraction is done with larger r, i.e. d = d/r). - A solid theoretical analysis of this method is needed to better understand how robust it is. - Can this test be used to quickly determine if an integrand is bad for Exp-Sinh to begin with? - Rob RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - robve - 04-24-2021 02:31 AM Some progress. The following updated and improved method predicts an optimal splitting point d for Exp-Sinh quadratures \( \int_a^\infty f(x)\,dx = \int_a^d f(x)\,dx + \int_d^\infty f(x)\,dx \). The method uses bisection with an exponential scale. The method inspects 2 or 4 points to check if an optimization is applicable. Bisection uses just 8 points to find a close-to-optimal d. This reduces the overhead to only 5.95 evaluation points on average for the 208 integrals tested, requiring 179.38 points each on average with eps=1e-9. Code: // return optimized Exp-Sinh integral split point d This new method of optimization is generic and not specifically tailored to the 208 integrands. Integrands that are suitable for Exp-Sinh will benefit, but those that do not converge or very slowly converge such as periodic and oscillating functions will not benefit from an optimized splitting point d. Of the 208 integrals tested, 29 are improved significantly in accuracy and/or number of points evaluated (63 fewer points on average). Of these 208 integrands, 14 are slightly worse (11 more points on average). However, practically there is almost no impact because 8 of these 14 integrands are not suitable for Exp-Sinh quadrature and return a large error with and without the optimized d. The full Exp-Sinh quadrature results with eps=1e-9 are listed in Appendix C. - Rob RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - Albert Chan - 04-24-2021 08:24 PM (04-24-2021 02:31 AM)robve Wrote: Some progress. The following updated and improved method predicts an optimal splitting point d for Exp-Sinh quadratures \( \int_a^\infty f(x)\,dx = \int_a^d f(x)\,dx + \int_d^\infty f(x)\,dx \). The method uses bisection with an exponential scale. The method inspects 2 or 4 points to check if an optimization is applicable. Bisection uses just 8 points to find a close-to-optimal d. Max. of 12 points ... impressive For illustration purpose, I tried 1 from Appendix C, where suggested d does most good. (there were 1 that does better, but integrand is oscillatory, so it might be just luck) lua> f = function(x) local y=sqrt(x*x-1); return exp(-y*11/1000)*x/y end lua> Q.exp_sinh_opt_d(f, 1) -- default eps=1e-9, d=1. 512 Code: N x f(1+x) f(1+x)*x sign(top-bot) I also made a version based on peak, and extrapolate for x-intercept. I've noticed after the peak, the curve mostly go straight down. (code use tangent line of last point, of the fitted quadratic) Of course, with peak, there are really 2 valleys. Code assumed optimal d is to the right of peak. Code: function Q.peak(f, a, d) lua> Q.peak(f, 1) 89.13375894266683 399.8238469921945 Note that code evaluated an extra point passes the peak (when points are too close) This is to get a more reasonable slope for the tangent line. Without the extra point, we would get peak, x-intercept ≈ 88.25, 9106. Code: N x f(1+x) f(1+x)*x Let's see effect of suggested d, vs default d=1 lua> function quad(f,...) local s,e = Q.quad(Q.count(f),...); return s,e,Q.n end lua> quad(f, 1, huge) -- default d=1 90.90909088146049 3.999609164190213e-009 273 lua> quad(f, 1, huge, 512) -- sign change based d 90.90909089915341 6.360683358493127e-011 143 lua> quad(f, 1, huge, 400) -- x-intercept based d 90.90909089845148 2.0323842611238905e-011 143 lua> quad(f, 1, huge, 89) -- peak based d 90.90909089656193 4.928270670014641e-011 141 The peak may be used for d. In that case, exp-sinh transformed plot, when folded, turn into half a bell-shaped curve. RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - Albert Chan - 04-26-2021 03:08 PM An improvement to previous post Q.peak(). Instead of calculating f(a+x)*x, this version use f(a+x), saving some computations. Bonus: this may avoid overflow/underflow issues, if x is huge/tiny. Code: function Q.peak(f, a, d) -- find peak of f(a+x)*x, guess=d Code assumed peak is bell-shaped, not bumpy. Also, code is optimized for peak close to user inputted d. Example, first integral from qthsh.pdf Appendix C: lua> f = function(x) return exp(-x)/x end lua> Q.peak(f, 1) -- default d=1 0.5980678336446792 3.218395385172793 With default d=1, code does 3 function evaluations. (note: code optimized away last column) Code: N x f(1+x) f(1+x)*x lua> Q.quad(Q.count(f), 1, huge), Q.n -- d = 1 (default) 0.2193839343909888 129 lua> Q.quad(Q.count(f), 1, huge, 3.218), Q.n -- d ≈ extrapolated x-intercept 0.21938393439552076 69 Update: code adjusted to quit early, if detected sign changes. RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - robve - 04-29-2021 07:33 PM (04-26-2021 03:08 PM)Albert Chan Wrote: An improvement to previous post Q.peak(). Great! The overhead cost to evaluate the peak per integrand is low, only 3.4 on average for the 208 integrals The overall results with respect to reducing the number of Exp-Sinh evaluations needed per integrand for eps=1e-9: 91 improved by 65.9 fewer evaluations on average 91 are worse by 45.3 more evaluations on average Funny the split in 91 and 91. Coincidence? To compare, the current version of exp_sinh_opt_d for eps=1e-9 gives: 29 improved by 63.2 fewer evaluations on average 14 are worse by 11.3 more evaluations on average (almost all oscillatory cases that are known to be problematic for Exp-Sinh and are marked N/A) I noticed that when a sign change is detected, peak() also does overall very well, except for one strange case that costs a lot more, 180 points more for log(1+9*(x*x))/(1+16*(x*x)) where d=10.9477 which for a small d<1 is better, meaning the movement of d is in the wrong direction? However, for the remaining 28 (or so) cases peak() can be closer to the optimum, simply because exp_sinh_opt_d() produces geometric values for d up to a large d=2^16 while peak() assumes the optimum is close to the given d (according to Albert). However, for exp_sinh_opt_d() we could refine d, e.g. with another step or with interpolation, which not done in the current exp_sinh_opt_d() version. The tentative(!) results are in the attached PDF for exp_sinh_opt_d() (left) and peak() (right), with yellow rows indicating exp_sinh_opt_d() was applicable due to a sign change and orange rows also having a sign change but are marked N/A for bad ACCURACY because of large errors of the integration due to oscillatory functions etc. so these are not interesting to compare. The column ACCURACY shows IMPROVED if the abs.err is lower than the original unoptimized Exp-Sinh integral abs.err (not shown in the PDF). However, ACCURACY can be noisy because the abs.err is so small. The abs.err of the relevant cases is mostly better than the specified eps=1e-9 anyway, meaning we should be fine anyway: [attachment=9428] I feel that progress has been made for both methods. However, when I have time, I plan to take a closer look at further improvements and directions to go with this. Also, I assume something similar can be done for Sinh-Sinh to split the integral at a more optimal point in some cases. Albert, you have the following "magic numbers" hardcoded without explanation: while L/C > 2.353 do while R/C > 0.425 do Are these empirically established? - Rob RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - Albert Chan - 04-29-2021 11:38 PM (04-29-2021 07:33 PM)robve Wrote: I noticed that when a sign change is detected, peak() also does overall very well, except for one strange case that costs a lot more, 180 points more for log(1+9*(x*x))/(1+16*(x*x)) where d=10.9477 which for a small d<1 is better, meaning the movement of d is in the wrong direction? Q.peak() got the direction wrong. (with points at 1/4, 1/2, 1. left side intercept ≈ 0.158) Q.peak() always go for the x-intercept of the right. In other words, it tried to push bulk of the area to \(\int_a^{a+d}\) Sometimes that is not appropriate, when we really need more points close to a. Without knowing the shape of curve, peak for d is the safe choice. Quote:Albert, you have the following "magic numbers" hardcoded without explanation: With quadratic fit, last two points cannot be too flat, otherwise tangent line would be way off. I had based on \(\int_0^∞ e^{-mx}\,dx\), with optimal d ≈ 6/m to 7/m. Let f(x) = exp(-m*x), g(x) = f(x)*x With g(2x)/g(x) ≈ 85%, we considered it just passes the peak. f(2x)/f(x) ≈ 0.85/2 = 0.425, or reverse direction: 1/0.425 = 2.353 With 85% setting, x-intercept roughly hit the sweet spot. lua> Q = require 'quad' lua> F = function(m) return function(x) return exp(-m*x) end end lua> for m=1,9 do p,x=Q.peak(F(m)); print(m, m*x) end 1 5.734205371025561 2 5.734205371025561 3 4.41325021172599 4 5.734205371025561 5 4.509031895026867 6 4.41325021172599 7 8.628727480200146 8 5.734205371025561 9 4.841791367031226 RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - Albert Chan - 04-30-2021 05:13 PM (04-29-2021 11:38 PM)Albert Chan Wrote: Without knowing the shape of curve, peak for d is the safe choice. This is work in progress, but if we got peak and both x-intercepts, we have an idea of curve shape. Code: function Q.peak2(f, a, d) -- find peak of f(a+x)*x, guess=d lua> f = function(x) return log(1+9*(x*x))/(1+16*(x*x)) end -- previous post example lua> Q.peak2(f1) 0.9456442962396107 -2.580895653494933 3.5331822306621703 Peak for f(x)*x, at x ≈ 0.9456 The other 2 numbers are x-intercepts, in log2 scale, relative to peak: Left-side x-intercept ≈ 0.9456 * 2^-2.581 ≈ 0.158 Right-side x-intercept ≈ 0.9456 * 2^3.533 ≈ 10.9 We should pick the steeper side (x-intercept with minimum log2 absolute value) If there is no steeper side, curve is relatively symmetrical, just use peak for d. Recommended d = left-side = 0.158 --- Both of these has peak at 1.0 ... which side to use for d ? lua> f1 = function(x) return exp(-x) end lua> f2 = function(y) return f1(1/y)/y^2 end lua> Q.peak2(f1) 0.932573172731174 -2.983219913988427 2.6203047422648424 lua> Q.peak2(f2) 1.072301916075236 -2.6203047422648424 2.9832199139884263 Noted the symmetry of f1, f2 intercepts. This is expected, f2 ≡ f1, with x=1/y, dx=-dy/y² Again, picking the steeper side, symmetry is carried to optimal d: f1 optimal d ≈ 2^2.62 ≈ 6.15 f2 optimal d ≈ 2^-2.62 ≈ 0.163 RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - robve - 06-28-2021 01:05 AM I've finalized the "Improving the Double Exponential Quadrature Tanh-Sinh, Sinh-Sinh and Exp-Sinh Formulas" article (link to PDF here) based on the discussions and shared findings in this thread. A lot has been said on this thread, so not everything could (or should) be put in the article. This thread has it all and some more - Rob RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - robve - 04-28-2022 01:35 AM I made two notable improvements to qthsh and quad that are documented in the updated article. The first post of this thread is also updated. The first improvement is a minor code optimization. The previous qthsh and quad code fragment with the convergence test is: Code: v = 2*s; That is, we compute \( s_{k+1} = s_k + p \) and the loop terminates when \( |2s_k-s_{k+1}| \le {\it tol}|s_{k+1}| \) . Note that \( 2s_k-s_{k+1} = 2s_k-s_k-p = s_k-p \) and we can make the code more elegant and slightly more optimal to avoid cancellation: Code: v = s-p; where variable v is now used to store the estimated absolute error and e is the estimated relative error with +eps in the denominator to avoid catastrophic blow up when the integral value s is close to zero. The second improvement is an addition to the article on pages 20 and 21 in section "Improved accuracy by adjusting the tolerance threshold". I felt that this section needed more data to justify the tol=10*eps choice and also needed quantitative comparisons of the estimated and actual errors for the 21 showcased integrals and the 818 test integrals. A new table is added to the article showing the estimated relative error e to the actual relative error. The table also shows the estimated absolute error v and the actual absulute error. Notable in this table (not shown here) is that the estimated relative error e almost always lies within one order of magnitude of the actual relative error, i.e. e estimates the accuracy of the result which may be off by one digit, but typically not more. I verified the accuracy of the estimated relative error e for a range of eps values 1e-5 to 1e-10 for the 818 test integrals: \[ \begin{array}{|r|c|c|c|c|c|c|} \hline {\it eps}= & 10^{-5} & 10^{-6} & 10^{-7} & 10^{-8} & 10^{-9} & 10^{-10} \\ \hline \mbox{average number of evaluations} & 57 & 69.4 & 81.7 & 93.4 & 106 & 132 \\ \hline \mbox{actual relative error} \le {\it eps} & 771 & 766 & 755 & 707 & 559 & 182 \\ \hline \mbox{estimated rel.err. is within 10}\times & 809 & 807 & 799 & 780 & 690 & 385 \\ \hline \end{array} \] This table shows the number of cases when the actual relative error≤eps on the second row and the number of cases when the estimated relative error is within 10× of the actual relative error on the third row, that is, e≤10eps if the actual relative error≤eps (the method converged) and e≥eps/10 if the actual relative error≥eps (the method failed to converge). The table suggests that e can be a reliable estimate of the relative error for eps up to 1e-9. There is a sharp drop-off in the number of correct cases at eps=1e-10, i.e. not many results meet the desired 1e-10 accuracy, but rather meet a 1e-9 accuracy. This makes sense when comparing qthsh to the VB code and the WP-34S code: \[ \begin{array}{|r|c|c|c|c|c|c|} \hline & \mbox{qthsh} & \mbox{VB} & \mbox{WP-34S} \\ \hline \mbox{average number of evaluations} & 106 & 97.8 & 62 \\ \hline \mbox{actual relative error} \le {\it eps} & 559 & 549 & 233 \\ \hline \mbox{estimated rel.err. is within 10}\times & 690 & 634 & 593 \\ \hline \end{array} \] It should be noted that the VB code succeeds for 796 integrands instead of 814 for the others. This is due to NaN issues that aren’t caught in the VB code. Overall, qthsh is more accurate, but at a cost of a slightly higher average number of function evaluations. To reduce the number of function evaluations in qthsh to 93.9 on average (for the 818 test cases), we can increase the tolerance, much like the VB code uses a higher tolerance to get the fewer 97.8 evaluations on average. However, for qthsh we use an optimal tol=160*eps that I empirically found to be optimal and is also largely independent of eps the integral. We also adjust the estimated relative error e accordingly: Code:
This reduces the function evaluations by over 10% with a minimal impact on accuracy: \[ \begin{array}{|r|c|c|c|c|c|c|} \hline {\it eps}= & 10^{-5} & 10^{-6} & 10^{-7} & 10^{-8} & 10^{-9} & 10^{-10} \\ \hline \mbox{average number of evaluations} & 47.5 & 59.2 & 68.9 & 82 & 93.9 & 106 \\ \hline \mbox{actual relative error} \le {\it eps} & 754 & 767 & 753 & 715 & 559 & 183 \\ \hline \mbox{estimated rel.err. is within 10}\times & 805 & 803 & 796 & 777 & 682 & 352 \\ \hline \end{array} \] By comparison, the 93.9 average number of evaluations of qthsh for eps=1e-9 is lower than the VB code. Also qthsh has a higher number of accurate results within the actual and estimated relative errors. PS. feel free to rerun these tests with the code and integrands in qthsh2.zip - Rob RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - Paul Dale - 02-18-2024 04:36 AM I wish I'd noticed this at the time (life has been way too busy for too many years). The related paper: https://www.genivia.com/files/qthsh.pdf isn't entirely accurate. The WP 34S integration code isn't written in C and doesn't use IEEE doubles. It is, rather, a keystroke program in XROM which uses the 34S's decimal floats. Still, I am impressed by how well it performed in the overall analysis. That the only notable negative being the underestimation of the error in one case is quite amazing. Pauli RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - robve - 02-18-2024 02:02 PM (02-18-2024 04:36 AM)Paul Dale Wrote: The related paper: https://www.genivia.com/files/qthsh.pdf isn't entirely accurate. The WP 34S integration code isn't written in C and doesn't use IEEE doubles. It is, rather, a keystroke program in XROM which uses the 34S's decimal floats. Thank you for your interest and for perusing the article. A quote from the article: "Tanh-Sinh C source code derived from the WP-34S Tanh-Sinh Python code (MIT licensed)". There is also a Visual Basic version "Tanh-Sinh V5.0 VB QUAD_TANH_SINH source code" in the article with "The full RPN source code for the WP 34S calculator integration program was written by M. César Rodríguez in 2017". The article lists a version of the WP34s code in C, but does not state that the WP34s code was originally written in C. The C version represents the WP34s code. Links are included to sources. - Rob RE: (PC-12xx~14xx) qthsh Tanh-Sinh quadrature - Nigel (UK) - 03-09-2024 11:32 PM I'd like to ask a question about the exp_sinh_opt_d split-point program on pages 31-32 of the qthsh.pdf booklet. On page 32, above the table, it says Quote: If the sign of \(h\) changes from negative to positive, then \(d\) is multiplied by \(2^{k-1}\).This fits in with what the table below shows - for this function, \(h\) changes from negative to positive as \(r\) increases, so \(d\) (initially 1) gets set to 32. The text below the table confirms that \(d=32\) is the value estimated by the method. However, rather than checking directly how the sign of \(h\) changes, the program tests if (fabs(lfl) < fabs(lfr)), which isn't obviously the same thing. Indeed, for the data in the table this test is true, which means that the code returns \(d = 1/32\) rather than \(d = 32\). Am I misunderstanding the code, or the text? Sorry if the answer is obvious - it's late here, but I've looked at it for a while and I remain confused! Nigel (UK) |
