HP-9114A Disc Drive Battery Charger Model No.? (UK) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: HP-9114A Disc Drive Battery Charger Model No.? (UK) (/thread-16556.html) |
HP-9114A Disc Drive Battery Charger Model No.? (UK) - JohnStr - 03-29-2021 02:44 PM What is the product number of the 9114A Disc Drive 'Charger Module' which I should be using here in the UK (220-240V AC)? I've several different HP calc/accessory charger modules lying around but which is the correct one for the Disc Drive? Thanks. John S RE: HP-9114A Disc Drive Battery Charger Model No.? (UK) - Dave Frederickson - 03-29-2021 10:08 PM From the technical manual. The adapter/rechargers listed next are recommended for use with the HP 88014A Rechargeable Battery Pack. Model, AC Voltage, Identification HP 82059B, 90 to 120, United States HP 82066B, 210 to 250, Europe HP 82067B, 210 to 250, United Kingdom HP 82067B Opt 001, 210 to 250, United Kingdom HP 82068B, 210 to 250, Republic of South Africa HP 82069B, 90 to 120, Europe RE: HP-9114A Disc Drive Battery Charger Model No.? (UK) - JohnStr - 03-30-2021 05:55 PM Hi Dave, Many thanks for confirming HP 82067B recharger details. The HP 9114A has been dormant for 15 years so will probably require a new rechargeable battery before it fires up! Thanks, John S (03-29-2021 10:08 PM)Dave Frederickson Wrote: From the technical manual. |
