HP Prime capabilities - Printable Version
+--- Thread: HP Prime capabilities (/thread-16571.html)
HP Prime capabilities - sdiener17 - 03-31-2021 01:43 AM
Does downloading every single program to the hp prime from hpcalc.org make it more capable than you can possibly make any other graphing calculator? Are some of their programs apps and some are not meaning that they will be used in specific built in apps?[/size][/font]
RE: HP Prime capabilities - Dougggg - 04-01-2021 01:31 AM
Sone are going to be apps and some will be programs so should be installed appropaltely. Although the G2 version may have enough memory to hold all programs/Apps on hpcalc.org, one weakness of the prime there no way to organize them. So if you can dl what you need for your application then i would say it is a powerful as any other graphing calculator out there
RE: HP Prime capabilities - sdiener17 - 04-01-2021 01:53 AM
Which reset method of the hp prime deletes everything except for the apps and programs installed from hpcalc.org?
RE: HP Prime capabilities - BERNARD MICHAUD - 04-04-2021 09:26 PM
Reset Method to delete all except HP Apps.
https://www.hpmuseum.org/forum/thread-13914.html
Post #10
BM
