Parametric app questions - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Parametric app questions (/thread-1659.html) |
Parametric app questions - Rich - 06-18-2014 06:22 PM Hi, I have been using the Hp Prime to model control systems for school. One the plots i have been using is the parametric plot to model the Bode gain and phase diagrams which are typically plotted on a log-log scale. Does the Hp Prime have a log log scale option? Currently I am setting the function to Log(y), Log(x) to get the scaling right, but it would be nice to switch between log values and actual values quickly. Also, I am trying to come up with a solution to make my parametric plots, plot faster and smoother when x/y approaches an asymptotic value as T --> infinity. I set the T range pretty high and in turn that makes my plot very slow, freezing up, and crashes if i try to pinch zoom when its doing any sort of thinking. Thanks, While I am asking, maybe some more parametric plot love, too, like autoscale for tick marks, viewable asymptotes, slope, intercepts, and intersection. (I have not seen these on the TI nSpire CX CAS I have (for parametric), so maybe it's not possible...) RE: Parametric app questions - CR Haeger - 06-19-2014 02:00 AM I'm not aware of log scale settings available yet. Check on pg 2 of plot settings. Fixed step may be faster than adaptive. RE: Parametric app questions - Rich - 06-19-2014 05:11 AM Thank you, the change from adaptive settings to fixed segments helped a bit. |
