number base conversion for hp17b/17bii - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: number base conversion for hp17b/17bii (/thread-1660.html) |
number base conversion for hp17b/17bii - Don Shepherd - 06-18-2014 06:53 PM OK, you've got your old 17b or 17bii you use for all your financial needs, but now you need something to do number base conversions. There is no need to go to a scientific model, the solver is your friend. B1 = old base (2-10) B2 = new base (2-10) N = number to convert ANS = solve for this Either B1 or B2 must be 10. BC:ANS=\(\Sigma\)(I:0:LOG(N)\(\div\)LOG(B2):1:MOD(N:B2)\(\times\)B1I+0\(\times\)L(N:IDIV(N:B2))) RE: number base conversion for hp17b/17bii - Thomas Klemm - 06-19-2014 01:59 AM (06-18-2014 06:53 PM)Don Shepherd Wrote: BC:ANS=\(\Sigma\)(I:0:LOG(N)\(\div\)LOG(B2):1:MOD(N:B2)\(\times\)B1I+0\(\times\)L(N:IDIV(N:B2))) Very cool! Thanks for consistently bringing up this calculator. You don't need MOD if you combine the calculations from successive lines. Example: DEC → OCT Code: 2014 BC:ANS= 0\(\times\)L(K:FROM-TO) +N +\(\Sigma\)(I:1:LOG(N)\(\div\)LOG(TO):1: G(K)\(\times\)L(N:IDIV(N:TO)) +0\(\times\)L(K:FROM\(\times\)G(K)) ) Kind regards Thomas RE: number base conversion for hp17b/17bii - Thomas Klemm - 06-19-2014 09:06 AM A little shorter: BC:ANS= N+ (FROM-TO)\(\times\) \(\Sigma\)(I:0:LOG(N)\(\div\)LOG(TO):1: L(N:IDIV(N:TO))\(\times\)FROM^I ) RE: number base conversion for hp17b/17bii - Don Shepherd - 06-19-2014 01:45 PM (06-19-2014 09:06 AM)Thomas Klemm Wrote: A little shorter: Thomas, that is way cool! Thanks. The method I chose was based on how I learned to manually convert numbers from one base to another back in computer programming school in 1968. That method is described at the bottom of this page. I just converted those manual steps to an equivalent solver equation. I like your method also, it is simple and elegant. Don RE: number base conversion for hp17b/17bii - Thomas Klemm - 06-19-2014 02:06 PM (06-18-2014 06:53 PM)Don Shepherd Wrote: Either B1 or B2 must be 10. You could set either B1 or B2 to 100. This allows conversions between HEX and DEC. Example: CAFEHEX B1: 16 B2: 100 N: 12101514 ANS: 51,966 RE: number base conversion for hp17b/17bii - Don Shepherd - 06-19-2014 02:36 PM (06-19-2014 02:06 PM)Thomas Klemm Wrote:(06-18-2014 06:53 PM)Don Shepherd Wrote: Either B1 or B2 must be 10. I am stunned! I never thought that was possible. You are a true missle-man. RE: number base conversion for hp17b/17bii - Thomas Klemm - 06-19-2014 10:15 PM (06-19-2014 02:36 PM)Don Shepherd Wrote: I am stunned! I never thought that was possible. It's been there for a while: Base Conversion for HP-11C RE: number base conversion for hp17b/17bii - Thomas Klemm - 06-21-2014 10:18 PM Here's a program for the HP-12C: Code: 01 - 36 ENTER Example: 201410 → 37368 10 STO PMT 8 STO FV 2014 R/S RE: number base conversion for hp17b/17bii - Don Shepherd - 06-21-2014 11:27 PM (06-21-2014 10:18 PM)Thomas Klemm Wrote: Here's a program for the HP-12C: That is just amazing, Thomas. I'm sure the creators of NPV and delta-percent on the 12c never envisioned those functions being used for number base conversions. I tip my hat to you, you are "da man". RE: number base conversion for hp17b/17bii - Thomas Klemm - 06-21-2014 11:54 PM But then I realized that the 1:1 translation of my HP-11C program was shorter. And it uses only 3 registers. However it was fun to figure it out. Addendum: As long as the from-base PMT doesn't change the following lines could be removed: Code: 15 - 1 1 Of course you still have to calculate i once and store it. (06-21-2014 11:27 PM)Don Shepherd Wrote: That is just amazing, Thomas. I'm sure the creators of NPV and delta-percent on the 12c never envisioned those functions being used for number base conversions. I've seen this trick in Valentin's paper: HP-12C’s Serendipitous Solver |
