STARTVIEW and Programming - Printable Version
+--- Thread: STARTVIEW and Programming (/thread-16609.html)
STARTVIEW and Programming - Eddie W. Shore - 04-06-2021 12:17 AM
Does STARTVIEW automatically terminate a program? If it does, the user will not be able to solve an equation and stay in a program.
I received an email asking me advice for an equation library.
Example:
EXPORT sampleprgm()
LOCAL mh, ch, d;
mh:=2;   // after each calculation ask the user if they want to exit the program (1.  yes,  2. no)
WHILE mh==2 DO
// main menu
CHOOSE(ch,"title",list of choices);
// one of the menu choices
IF ch==1 THEN
CHOOSE(d,"title",list of choices_submenu);
IF d==1 THEN
calculations and commands here
[b]STARTVIEW(2,1)[/b]
CHOOSE(mh,"Quit?",{"Yes","No"});
END;    // end submenu choice (d)
END;   // end main menu choice (ch)
END;   // end the while loop
RE: STARTVIEW and Programming - roadrunner - 04-07-2021 12:26 AM
It seems it does not:
PHP Code:
EXPORT teststartview()
 MSGBOX
("before startview");
STARTVIEW(2);
MSGBOX("after startview");
END
-road
RE: STARTVIEW and Programming - Eddie W. Shore - 04-07-2021 02:54 PM
It leaves the startview as it's final destination.
Check this code out:
EXPORT teststartview2()
 MSGBOX("before startview");
 STARTVIEW(2);
 INPUT(A);
 B:=A+1;
 PRINT("B = "+STRING(B));
RE: STARTVIEW and Programming - C.Ret - 04-07-2021 07:36 PM
I see nothing special here, all seem to act as expected !?
If you want to terminate your code at the HOME or CAS view, you just have to specify it:
 STARTVIEW(2);                                   // Activate the Numeric View (exact display depending of the curent Application )
 INPUT(A);
 B:=A+1;
 STARTVIEW(-1)                                 // Activate the HOME or CAS view just before the end of code
See the inline ?-Help key for the different available views (specific to the current Application, user customized or global).
