How to run Python (new Prime) ? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: How to run Python (new Prime) ? (/thread-16692.html) |
How to run Python (new Prime) ? - OlidaBel - 04-19-2021 02:40 PM Hello, How can I run Python on a G2 ? There is no Python app on my calculator (unboxed a week ago). Should I install something ? Is there a documentation on this subject ? thank you. RE: How to run Python (new Prime) ? - KeithB - 04-19-2021 02:42 PM It is only Beta at this time. Look at the Beta threads. RE: How to run Python (new Prime) ? - OlidaBel - 04-19-2021 02:50 PM (04-19-2021 02:42 PM)KeithB Wrote: It is only Beta at this time. Look at the Beta threads. I understood Running Python is not a new feature... I see many posts on the web with Python examples, but none of them explain how they get Python module/app. I don't think only the new Beta can run Python. RE: How to run Python (new Prime) ? - toml_12953 - 04-19-2021 02:56 PM (04-19-2021 02:50 PM)OlidaBel Wrote:(04-19-2021 02:42 PM)KeithB Wrote: It is only Beta at this time. Look at the Beta threads. You can also use Python syntax in a CAS program in the shipping version of the OS. Perhaps that's what those programs you see are doing. Code: #cas RE: How to run Python (new Prime) ? - OlidaBel - 04-19-2021 03:11 PM (04-19-2021 02:56 PM)toml_12953 Wrote: You can also use Python syntax in a CAS program in the shipping version of the OS. Perhaps that's what those programs you see are doing. exactly. now it's ok. It was a hidden feature. It's also case sensitive, "DEF" is not accepted, I must write "def", etc. I'd rather try on a real keyboard ! at least, it works, Thank you. RE: How to run Python (new Prime) ? - dae - 05-11-2021 06:59 PM If you are trying this code in cas, first create and save the code exactly as is, in a program. Delete any template code (EXPORT, BEGIN, END) lines. Run the function, by calling <name of program>:<name of function>() For example, if code is saved as test01, in cas screen, type test01:pyhat() Fast way: open the emulator, copy/paste the code into a new program, then use the connectivy kit, to transfer the program to the physical Prime. |
