WP 34S Modulo Bug - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: WP 34S Modulo Bug (/thread-1686.html) |
RE: WP 34S Modulo Bug - Gerald H - 06-23-2014 01:45 PM So the story goes happily to bed with a bug fix. Farewell, you were an interesting thread. Not much use to me personally, can't reflash the operating system. Still "A nod's as good as a wink to a blind horse". RE: WP 34S Modulo Bug - jebem - 06-23-2014 05:40 PM (06-23-2014 01:45 PM)Gerald H Wrote: So the story goes happily to bed with a bug fix. You need a serial cable that is not available anymore. Or you may contact Eric asking for the reflashing service. RE: WP 34S Modulo Bug - Andreas - 06-23-2014 06:13 PM (06-23-2014 08:34 AM)Gerald H Wrote:(06-23-2014 07:31 AM)walter b Wrote: I don't see that. If you think there's a need to convince him, feel free to do it yourself. If these were your cogent arguments I don't want to hear your sardonic ones... Cheers Andreas RE: WP 34S Modulo Bug - Marcus von Cube - 06-23-2014 06:50 PM (06-23-2014 09:19 AM)Paul Dale Wrote: I already fixed this bug -- circa twelve hours ago now. Walter doesn't touch the code. That's for me and Marcus. As for the numeric code, it is almost exclusively me.A new build can be found in the SVN repository. RE: WP 34S Modulo Bug - pito - 06-23-2014 07:27 PM (06-23-2014 06:50 PM)Marcus von Cube Wrote: A new build can be found in the SVN repository.I've updated, rebuilt, flashed and my r3673 shows -4mod2=0. Thanks! RE: WP 34S Modulo Bug - Paul Dale - 06-23-2014 09:48 PM (06-23-2014 01:45 PM)Gerald H Wrote: Not much use to me personally, can't reflash the operating system. There is an easy work around for programs: Code: LBL'MOD' Or you could use RMDR which is correct but gives different results when the argument's signs are different. - Pauli RE: WP 34S Modulo Bug - pito - 06-23-2014 10:09 PM (06-23-2014 01:45 PM)Gerald H Wrote: Not much use to me personally, can't reflash the operating system.Go to a mobile phone accessory shop (or m.phone service center) and ask for the "CA-42" USB data cable (the cheap clone with blue connectors, not the original Nokia one(!)). It costs almost nothing. Cut the mobile phone side connector off, there are only 3 wires inside: Code: Blue - GND Disclaimer: do it at your own risk, no warranties of any kind ![]() |
