how to use HP PRIME commands in a python program - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: how to use HP PRIME commands in a python program (/thread-16876.html) |
how to use HP PRIME commands in a python program - robmio - 05-04-2021 04:24 PM Hello, How can I use HP PRIME commands in a python program? How do I use, for example, the PIXON_P command in a python program? Thanks a lot, Roberto. RE: how to use HP PRIME commands in a python program - toml_12953 - 05-04-2021 07:11 PM (05-04-2021 04:24 PM)robmio Wrote: Hello, eval("PIXON_P ...") replace ... with your parameters. You don't need to use the HPPL version, though. Python has the graphics commands natively. Just use Code: from hpprime import * then use pixon or pixon_c in your program. It's a lot faster to do it that way. RE: how to use HP PRIME commands in a python program - robmio - 05-05-2021 05:00 AM Thanks a lot, Roberto RE: how to use HP PRIME commands in a python program - robmio - 05-05-2021 05:49 AM I ask another neophyte question: after writing a program with PYTHON, how can I call it up and make it work, in HOME or CAS screen? |
