HP-67 Conversion-Factors-Label - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP-67 Conversion-Factors-Label (/thread-16902.html) |
HP-67 Conversion-Factors-Label - tuxfan - 05-09-2021 09:52 AM After repairing an HP-67, I made a copy of the label on the back with a graphics program. Maybe it's useful to someone else too. If you want, you can download the copy of the label here Password is hew-pack-67 After removing the original label, I put the copy on the calculator and kept the original for later. I printed out the copy with a laser printer on normal paper and then treated it with a matt varnish. The label treated in this way was then attached to the calculator with a thin double-sided adhesive film. ############### 11.05.2021 I've changed the pdf files. The resolution was too low. ############### 11.05.2021 Correction of a typographical error (BRITISCH... to BRITISH...) RE: HP-67 Conversion-Factors-Label - Siegfried - 05-09-2021 09:36 PM Thank you for sharing! RE: HP-67 Conversion-Factors-Label - tuxfan - 05-11-2021 12:51 PM (05-09-2021 09:52 AM)tuxfan Wrote: After repairing an HP-67, I made a copy of the label on the back with a graphics program. Maybe it's useful to someone else too. If you want, you can download the copy of the label here I've changed the pdf files. The resolution was too low. RE: HP-67 Conversion-Factors-Label - Massimo Gnerucci - 05-11-2021 02:57 PM (05-11-2021 12:51 PM)tuxfan Wrote: I've changed the pdf files. The resolution was too low. Sorry, just found this: "1 BRITISCH THERMAL UNIT =..." RE: HP-67 Conversion-Factors-Label - tuxfan - 05-11-2021 07:13 PM (05-11-2021 02:57 PM)Massimo Gnerucci Wrote:(05-11-2021 12:51 PM)tuxfan Wrote: I've changed the pdf files. The resolution was too low. Hello Massimo, thanks for the hint. I have now, hopefully, eliminated the last mistake. Sorry to everyone for any inconvenience. tuxfan RE: HP-67 Conversion-Factors-Label - Massimo Gnerucci - 05-11-2021 07:19 PM (05-11-2021 07:13 PM)tuxfan Wrote:(05-11-2021 02:57 PM)Massimo Gnerucci Wrote: Sorry, just found this: "1 BRITISCH THERMAL UNIT =..." Sorry? Not at all, you're welcome! And thanks a lot. RE: HP-67 Conversion-Factors-Label - albertofenini - 06-04-2021 03:28 PM Thank you very much !!! RE: HP-67 Conversion-Factors-Label - Archilog - 06-05-2021 12:12 AM Great, thank you. |
