Graphic Calc in 1974? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: Graphic Calc in 1974? (/thread-1692.html) |
Graphic Calc in 1974? - Matt Kernal - 06-23-2014 04:59 AM A few months back, I was watching a TV network that plays old shows from the 60's thru the 80's. I stopped the DVR to take these photos from the crime drama I was watching (Columbo ), that aired in 1974 (I verified the year at the closing credits). What stood out to me is what looks to be a graphic calculator in the man's left hand. Obviously it can't be, but what do you think it is? <<Sorry, I tried uploading the photos multiple times to the forum, but every time I tried to Insert Into Post then Preview Post, they just disappeared. I gave up. This is a mystery for Columbo to solve!>> Instead, here are Dropbox Links to slightly higher resolution copies than what are allowed in the forum: Pic #1 and Pic #2. Edit: After receiving some good advice, here's another attempt at attaching the pics to the thread.. It seems to have worked - Thanks Jeff! [attachment=881] [attachment=882] Matt RE: Graphic Calc in 1974? - Massimo Gnerucci - 06-23-2014 06:20 AM (06-23-2014 04:59 AM)Matt Kernal Wrote: A few months back, I was watching a TV network that plays old shows from the 60's thru the 80's. I stopped the DVR to take these photos from the crime drama I was watching (Columbo ), that aired in 1974 (I verified the year at the closing credits). What stood out to me is what looks to be a graphic calculator in the man's left hand. Obviously it can't be, but what do you think it is? John Titor was there! RE: Graphic Calc in 1974? - HP67 - 06-23-2014 06:51 AM It must be a prop of some kind. Look how thin it is, nothing was made so slim in the old days. RE: Graphic Calc in 1974? - kusmi - 06-23-2014 08:42 AM (06-23-2014 04:59 AM)Matt Kernal Wrote: Obviously it can't be, but what do you think it is? I think this is the first HP Prime prototype from HP - it just took them 40 years to perfect it! ;-) RE: Graphic Calc in 1974? - walter b - 06-23-2014 09:21 AM (06-23-2014 08:42 AM)kusmi Wrote: I think this is the first HP Prime prototype from HP - it just took them 40 years to perfect it! ;-) If that's now the result of 40 years striving for perfection then beware! d;-) RE: Graphic Calc in 1974? - Jeff O. - 06-23-2014 11:51 AM (06-23-2014 04:59 AM)Matt Kernal Wrote: <<Sorry, I tried uploading the photos multiple times to the forum, but every time I tried to Insert Into Post then Preview Post, they just disappeared. I gave up. This is a mystery for Columbo to solve!>> I have had a similar issue. I am probably doing it the hard way, but the way I get around it is to add the attachment, then insert into post. That will add something like "[attachment=xxx]" to the top of your message, where "xxx" will be the number assigned your attachment by the forum software. Then I type in an image insertion code: Code: [img]http://www.hpmuseum.org/forum/attachment.php?aid=xxx[/img] Replace the xxx by the real attachment number, and the image is inserted into your post. (06-23-2014 04:59 AM)Matt Kernal Wrote: Instead, here are Dropbox Links to slightly higher resolution copies than what are allowed in the forum: Dropbox is blocked at my current location, so if you get a chance and feel like it, try my method above to insert your pictures here. Jeff RE: Graphic Calc in 1974? - Mark Hardman - 06-23-2014 03:28 PM (06-23-2014 04:59 AM)Matt Kernal Wrote: What stood out to me is what looks to be a graphic calculator in the man's left hand. Obviously it can't be, but what do you think it is? It looks like a Litronix 4 banger of the era. [attachment=884] RE: Graphic Calc in 1974? - Sylvain Cote - 06-23-2014 03:55 PM (06-23-2014 03:28 PM)Mark Hardman Wrote: It looks like a Litronix 4 banger of the era. Yep! I think you are right. RE: Graphic Calc in 1974? - Jeff O. - 06-23-2014 04:32 PM (06-23-2014 04:59 AM)Matt Kernal Wrote: Edit: After receiving some good advice, here's another attempt at attaching the pics to the thread.. It seems to have worked - Thanks Jeff! Almost got it , here are the larger versions in a post: RE: Graphic Calc in 1974? - Matt Kernal - 06-23-2014 08:25 PM (06-23-2014 03:28 PM)Mark Hardman Wrote: It looks like a Litronix 4 banger of the era. Whew! Thank goodness that mystery is solved! I thought we were having a hiccup in the time-space continu.. well, you know the rest. Thanks all. |
