WP 34S (HP 30B) R18 damaged - alternative? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: WP 34S (HP 30B) R18 damaged - alternative? (/thread-16952.html) |
WP 34S (HP 30B) R18 damaged - alternative? - Siegfried - 05-16-2021 04:40 PM I managed to lift the pad of R18 by snagging the cable from the IR diode. Is there any alternative way to install the cable or do I have write IR off for that unit? Thanks! RE: WP 34S (HP 30B) R18 damaged - alternative? - Sadsilence - 05-18-2021 07:56 PM Looking at the schematics and layout I would say "jackpot". Lifted pad is directly connected to CPU Pin 94/94A. Wire is not on top lane. Sorry. RE: WP 34S (HP 30B) R18 damaged - alternative? - Siegfried - 05-18-2021 09:00 PM (05-18-2021 07:56 PM)Sadsilence Wrote: Looking at the schematics and layout I would say "jackpot". Lifted pad is directly connected to CPU Pin 94/94A. Wire is not on top lane. Sorry. Well, I'll try to fail better with my last remaining unit... Thanks for looking it up. |
