Squaring the Binomial - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Squaring the Binomial (/thread-16991.html) |
Squaring the Binomial - MullenJohn - 05-22-2021 03:54 PM Help, Using my HP Prime calculator I am try to square the binomial (12*c^4 + 0.25*a^6*c)^2. I was expecting something like (a^2 + B^2 + c) but I am getting only a number like 2.9887... Please tell me how to expand the binomial with just the literals. Thanks - Cheers! RE: Squaring the Binomial - Joe Horn - 05-22-2021 04:37 PM (05-22-2021 03:54 PM)MullenJohn Wrote: Help, Your variables might have values assigned to them. Purging them will force Prime to use them symbolically. Try purge(c) or del(c), and then try your simplification again. Suggestion: Any time CAS sees a decimal point, it flips from "Exact" mode into "Approximate" mode. To use CAS to its full potential, avoid including any decimal points in CAS. E.g. use 1/4 instead of 0.25. RE: Squaring the Binomial - Albert Chan - 05-22-2021 05:40 PM Instead of purging variables, we can quote them. (quote(expr) == 'expr') Quoting returns its argument unevaluated. Cas> a:=b:=c:=1 Cas> expand('(12*c^4 + 1/4*a^6*c)^2') 1/16*a^12*c^2+6*a^6*c^5+144*c^8 --- BUG report: sometimes quoting does not work. HP Prime emulator 2.1.14181 (2018 10 16): Cas> expand('(12*c^4 + 1/4*a^6*c)^2') 150.0625 Not only quote not working, results somehow turned approximate. |
