DIMGROB back from Graphics Variable? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: DIMGROB back from Graphics Variable? (/thread-17000.html) |
DIMGROB back from Graphics Variable? - matalog - 05-24-2021 09:24 PM Is there a way to get a DIMGROB from a G1 Graphic Variable, so that I can include it in a program, instead of having to transport the .png file from which the G1 is created with the program, for another person to try out? So if G1 is defined on a HP Prime, is there a way to get a DIMGROB from the calc? RE: DIMGROB back from Graphics Variable? - matalog - 05-26-2021 10:07 PM I found a way to do it, but it will obviously require a large amount of space in the program, it works though, and can be used to put sprites into a program and not need to send any files along with the program. Code: EXPORT NH() This saves the colours of the 'sprite' or graphic which can be loaded as a PNG, to a notes file called COL, which can be viewed on computer, and then pasted as a DIMGROB, and therefore entered into a program. |
