32SII ROM versions and serial numbers - any way to correlate? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: 32SII ROM versions and serial numbers - any way to correlate? (/thread-17112.html) |
32SII ROM versions and serial numbers - any way to correlate? - Dave Britten - 06-15-2021 01:20 PM I'm keeping my eyes out for a USA or Singapore 32SII, and I want one with ROM version 1 (i.e. no - or fewer - fraction bugs). My USA ROM 0 unit is 3116, so 1991. My Indonesian ROM 1 unit is ID1, which I believe is 2001. So the update happened somewhere in that 10-year span, I'm guessing closer to 1991 than 2001. Anybody have a few data points to add so we can narrow it down? Then I'll have a better idea of serial number ranges to look for. RE: 32SII ROM versions and serial numbers - any way to correlate? - twoweims - 06-15-2021 02:00 PM I have a 32SII here that I rarely use. it is a 1988 Indonesia (ID82901347) Version. But I have no idea how to tell the ROM version. I realize that this is not the model that you are looking for, but I am curious to find out how to tell the ROM version. RE: 32SII ROM versions and serial numbers - any way to correlate? - Dave Britten - 06-15-2021 02:14 PM (06-15-2021 02:00 PM)twoweims Wrote: I have a 32SII here that I rarely use. it is a 1988 Indonesia (ID82901347) Version. It's not 100% confirmed, but when you run the self-test and get the 32SII-OK message, either the 0 or 1 anunciator will be displayed. This is believed to indicate the ROM version. To run the self-test, hold ON and press y^x. Press any key to step through the tests until you get to the keyboard test, then press each key in order, starting at the top left (square root), and proceeding left to right, top to bottom. RE: 32SII ROM versions and serial numbers - any way to correlate? - Didier Lachieze - 06-15-2021 02:29 PM I have a ROM 1 32SII from 1992: 3228S, it doesn't seem to have the fraction bugs. RE: 32SII ROM versions and serial numbers - any way to correlate? - J-F Garnier - 06-15-2021 02:45 PM This thread gives several ROM samples of version vs datecode. My 32SII, ver.1, is ID9 (assumed 1999, in accordance with my date of purchase). On the date of the introduction of rev."1": Rev. "A" and "B" are mentioned by Eric Vogel in the HHC 1991 conference ("Reengineering the HP 32S", at about 23'). J-F RE: 32SII ROM versions and serial numbers - any way to correlate? - Dave Britten - 06-15-2021 02:46 PM (06-15-2021 02:29 PM)Didier Lachieze Wrote: I have a ROM 1 32SII from 1992: 3228S, it doesn't seem to have the fraction bugs. Thanks! Must have been very early in the product lifecycle that it was corrected, then. I bet that anything after 3228 (and possibly some prior to that) would be ROM 1. RE: 32SII ROM versions and serial numbers - any way to correlate? - BillBee - 06-15-2021 08:02 PM 3329S here. Gives the "1" above the "OK". -Bill RE: 32SII ROM versions and serial numbers - any way to correlate? - mfleming - 06-15-2021 11:31 PM 3219S is rev 1 RE: 32SII ROM versions and serial numbers - any way to correlate? - Csaba Tizedes - 06-20-2021 09:22 PM 3450S ROM 1 3311S ROM 1 |
