Possible to ORDER libraries in port on 48/50? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Possible to ORDER libraries in port on 48/50? (/thread-1724.html) |
Possible to ORDER libraries in port on 48/50? - HP67 - 06-26-2014 06:31 PM Is it possible to sort and reorder the way libraries are listed in the port menu like you can do for variables? RE: Possible to ORDER libraries in port on 48/50? - Raymond Del Tondo - 06-26-2014 08:16 PM At least in the HP 48 Series, the order is dependent on the Library number. Maybe Filer48 allows more sorgt criteria for the library view. RE: Possible to ORDER libraries in port on 48/50? - Gerald H - 06-27-2014 05:17 AM On HP 49G: in Filer, "S" key sorts for size. RE: Possible to ORDER libraries in port on 48/50? - HP67 - 06-27-2014 06:28 AM (06-26-2014 08:16 PM)Raymond Del Tondo Wrote: At least in the HP 48 Series, the order is dependent on the Library number. It looks to me like the order on the HP 48, both in what's displayed by |-> LIBRARY and <-| PORTS portno are based on chronological order, just like global variables. On the 50g they do appear in lib# order in the LIB menu but in the port menu they appear in chronological order. But there doesn't appear to be a way to sort them on either device. The 50g filer does allow you to sort in the filer, but when you exit nothing has changed. RE: Possible to ORDER libraries in port on 48/50? - Gerald H - 06-27-2014 09:22 AM You wish to change the physical location of libraries in a port? What for? There is a library, # 1622 Port Manager, that gives more insight to ports &, with some fiddling, can be used to reorder a port. RE: Possible to ORDER libraries in port on 48/50? - HP67 - 06-27-2014 09:31 AM Thanks. I wanted to know if it's possible without adding programs, like you can do Code: VARS SORT ORDER |
