How to specify full directory path in Python - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: How to specify full directory path in Python (/thread-17310.html) |
How to specify full directory path in Python - jfelten - 08-03-2021 12:56 AM Whenever I run something like Code: import uio it gives me OSError: 0, which from my experience translates to "file not found" I was wondering how I am supposed to format a directory on the Prime. RE: How to specify full directory path in Python - Dougggg - 08-03-2021 03:22 AM Reading from the file section of the python app I was able to use with open("test.txt",'r',encoding = 'utf-8') as f: and with open("test.txt",'w',encoding = 'utf-8') as f: wrote the file to the file section of the app looks like the main.py is stored there to some maybe if you add "Files" to the path RE: How to specify full directory path in Python - jfelten - 08-03-2021 11:31 AM What if I want to open files from different apps, or if I want to access file in the root directory, like cas.hpesettings, or any of the PPL programs? How to I format the path for stuff like that? RE: How to specify full directory path in Python - Tim Wessman - 08-03-2021 12:16 PM I was not involved with this part, but I am quite certain that the "root" directory for the python code will be considered to be inside the app... security concerns and stability being the primary drivers I would assume. Probably cannot access without some sort of path traversal bug. RE: How to specify full directory path in Python - jfelten - 08-22-2021 04:49 PM Is it possible to access files from other apps using sys.path? |
