HP50g Font Format - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: HP50g Font Format (/thread-17363.html) |
HP50g Font Format - Neve - 08-17-2021 12:22 AM Hi, Since the calculator let’s you browse for other fonts, what is the appropriate font format used by the HP50g? .OTF and .TTF don’t seem to be compatible. The connectivity kit wont let me upload them to the calculator. Or maybe I’m doing this wrong way… Thanks RE: HP50g Font Format - Joe Horn - 08-17-2021 12:30 AM The 50g uses a proprietary font format. Its internal structure was described by David Haguenauer in this article: https://www.hpcalc.org/details/2982 HP 49G/50g fonts are simple bitmaps, not scalable vector fonts like "TrueType" or anything fancy like that. Several fonts are available at hpcalc.org. RE: HP50g Font Format - Neve - 08-17-2021 12:38 AM (08-17-2021 12:30 AM)Joe Horn Wrote: The 50g uses a proprietary font format. Its internal structure was described by David Haguenauer in this article: https://www.hpcalc.org/details/2982 Thank you very much!! |
