HP82143A Repair - Paper Advance and Round O-rings - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP82143A Repair - Paper Advance and Round O-rings (/thread-17414.html) |
HP82143A Repair - Paper Advance and Round O-rings - cesarb94 - 08-31-2021 11:29 AM Hello, I would like to share my experience with repairing the paper advance rollers for my HP82143A thermal printer. Thanks to some members I was informed a good replacement for the rubber rollers on the paper advance mechanism for this printer, which were square profile o-rings. Unfortunately they seem to be non existent here in Brazil so I ended up using round profile ones. I've installed two on each side of the shaft and then put a tiny amount of glue on the o-ring edges. Attached is a picture of how it looked like. So far I tested the printer with original HP thermal paper as well as a new roll of thermal paper that is used for credit card machines. I used all 25m of it with no issues so far. Best regards. RE: HP82143A Repair - Paper Advance and Round O-rings - Geoff Quickfall - 09-05-2021 06:49 PM Excellent repair, thanks for the input. Geoff RE: HP82143A Repair - Paper Advance and Round O-rings - EugeneNine - 09-06-2021 01:28 AM hmm, i wonder if they could be printed from tpu RE: HP82143A Repair - Paper Advance and Round O-rings - [kby] - 09-07-2021 04:13 AM There was someone on TAS that sells square o-rings for 65/67/97 card reader rebuilds. I think those worked when I tried although they were a bit tight. I’ve also used shrinkwrap tubing and silicone rubber tubing, I think. It’s been a while. The trickiest part is ensuring both sides are both the same size. |
