Question: How to set it so results display nicely like textbook - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Question: How to set it so results display nicely like textbook (/thread-17508.html) |
Question: How to set it so results display nicely like textbook - Lain - 09-23-2021 01:05 AM Question: How to set it so small numbers display as 135.79 and large numbers display as 1.357e20 and never display things like 3*sqrt(5) and when result is a whole number, just say 15. instead of 15.000e0 Thank you! RE: Question: How to set it so results display nicely like textbook - Joe Horn - 09-24-2021 03:15 AM (09-23-2021 01:05 AM)Lain Wrote: Question: How to set it so In Home Settings, page 1, set the Number Format to Standard, and on page 2, turn off the Intelligent Math option (it only exists in more recent firmware versions). Then stay in Home view. Although CAS view is intended for exact math and symbolic math, you can force it to return numeric approximations in CAS Settings, page 1, uncheck the "Exact" setting. |
