Is an infrared printer still worth getting? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Is an infrared printer still worth getting? (/thread-17539.html) |
RE: Is an infrared printer still worth getting? - toml_12953 - 10-15-2021 01:30 PM (10-15-2021 09:49 AM)Siegfried Wrote:(10-12-2021 08:04 PM)striegel Wrote: This must sound like bragging, but I feel really lucky that I found one for only $18.00 back in 2018. Now, this one didn't come with a box, manual, or AC power supply but it arrived in great condition and even came with a nearly-full roll of thermal paper installed.I got a B with repaired battery terminals for 40EUR including shipping last June and a fully boxed A (sold together with a box full of calcs) for about about the same. They seem to see less love in Europe. If you want to build your own interface, you can set up any USB-capable printer to work with HP "Redeye" IR. Then you don't have to modify the printer. http://www.mh-aerotools.de/hp/red-eye/HP-IR%20Receiver%20with%20Arduino.pdf RE: Is an infrared printer still worth getting? - teenix - 10-15-2021 11:01 PM Anyone tried these cheers Tony RE: Is an infrared printer still worth getting? - Gerson W. Barbosa - 10-16-2021 12:28 AM (10-15-2021 01:18 PM)Thomas Okken Wrote: (Is overclocking Pioneers even possible? When I was in college, the college bookstore offered a service where they would modify the oscillator and double the speed of 41s and Voyagers, but that was before the Pioneers came out...) This software speedup, courtesy of Gene, worked on an early HP-42S I don’t have anymore: http://www.rskey.org/gene/hpgene/hp42fast.htm RE: Is an infrared printer still worth getting? - Dave Britten - 10-16-2021 12:59 AM There's also a hardware double speed mod for the 42S: http://www.finetune.co.jp/~lyuka/interests/calc/hp42s/#doublespeed Might work on the 17BII and 27S too, but not quite as meaningful there. RE: Is an infrared printer still worth getting? - tcab - 10-16-2021 08:40 PM (10-02-2021 03:51 PM)Eddie W. Shore Wrote: … the Online emulator is a life/time saver. I use Free42 PC emulator for my DM42 programs. There’s also the option of buying a modern, reliable Epson thermal printer that prints so fast it makes your head spin (think supermarket checkouts) - or other cheaper hobby thermal printers. They won’t interface with a real HP calculator of course but you can print to them from Free42 using my Print42 software https://print42.atug.com/ which has special Free42 support. RE: Is an infrared printer still worth getting? - BobVA - 10-16-2021 10:08 PM (10-15-2021 01:18 PM)Thomas Okken Wrote: Well, at least you might be able to keep DELAY set to 0 at all times! Delay: Yes! If you're tracing a series of manual calculations (e.g. checkbook) a modern printer doesn't make much of a difference (other than noise) but for longer printouts, where DELAY kicks in (programs listings, register print, etc.), it's significantly faster with DELAY set to zero. Overclocking: That corrupts the underlying timing of the data signal, so printing isn't possible for something that's expecting an HP82240 compatible IR signal. See here. For a home built printer it should be possible to compensate for that in the software if the microcontroller is fast enough. Since a couple of modern HP82240 compatible printers have been noted above, maybe Eric or Swiss Micros might consider carrying them at retail for us, if the prices are reasonable. |
