x11-calc HP29 behaviour - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: x11-calc HP29 behaviour (/thread-17590.html) |
x11-calc HP29 behaviour - Mike T. - 10-16-2021 09:16 PM I don't have a real HP29 so I can't check the behaviour of my simulator against the real thing but it does seem a bit odd that if I switch off while running a program, the program automatically started to run (from the beginning) when I switch back on...? This may be because I'm currently saving the contents of ALL the registers not just the non volatile ones. (Fixing that is on my to do list!) RE: x11-calc HP29 behaviour - teenix - 10-16-2021 10:11 PM The ACT registers are not saved at switch off so everything they did were reset. cheers Tony |
