How to solve this non-linear system of equations? - Printable Version
+--- Thread: How to solve this non-linear system of equations? (/thread-1770.html)
How to solve this non-linear system of equations? - alexzkter - 07-02-2014 01:44 PM
[Image: se3zmu.jpg]
Making O3=x and O4=y
0.84=0.3606cos(45)+0.3824cos(x)+0.3912cos(y)
0=0.3606sin(45)+0.3824sin(x)+0.3912sin(y)
I want the results to be in the interval [0º 360º] for obvious reasons or even [-360º 360º]
Tried 3 times: 1st time with no interval, 2nd and 3rd time with same interval but different results, the last try ignored the interval.
[Image: 104l3di.png]
So I keep pressing enter and it keeps showing different results. Take a look:
[Image: 2dwapnn.png]
How can I directly get proper (possitive) angle values for my system ?
The condition should be something like... x<y AND x>0 AND y<360
RE: How to solve this non-linear system of equations? - slawek39 - 07-02-2014 03:59 PM
Use Advanced Graphing to fint initial solution.
Then use the applet Solve to find the exact solution.
RE: How to solve this non-linear system of equations? - parisse - 07-02-2014 05:15 PM
You can not use conditions for multivariate systems with approx coefficients, you can only give an initial guess, and if it is not far from a solution, fsolve will return a solution up to machine precision. Your solution does not seem to work by the way:
fsolve([eq1,eq2],[x,y],[11.3,302.5]) returns [-3.39546756307,313.410392968]
(with degree mode)
RE: How to solve this non-linear system of equations? - slawek39 - 07-02-2014 05:42 PM
Software Version (6030)
solve({0.84 = (0.3606*cos(45)+0.3824*cos(x)+0.3912*cos(y)),0 = (0.3606*sin(45)+0.3824*sin(x)+0.3912*sin(y))},{x,y},{0..12,-100..0})
and
fsolve({0.84 = (0.3606*cos(45)+0.3824*cos(x)+0.3912*cos(y)),0 = (0.3606*sin(45)+0.3824*sin(x)+0.3912*sin(y))},{x,y},{0..12,-100..0})
restart the calculator and emulator in degree mode.
RE: How to solve this non-linear system of equations? - alexzkter - 07-02-2014 05:54 PM
I didn't know how to use that App. I always plot functions inside the Solve app, but it didn't let me plot several equations at the same time, lol. Thanks.
(07-02-2014 05:15 PM)parisse Wrote:  You can not use conditions for multivariate systems with approx coefficients, you can only give an initial guess, and if it is not far from a solution, fsolve will return a solution up to machine precision. Your solution does not seem to work by the way:
(with degree mode)
So if coeficients were integer numbers I'd be able to use conditions for multivariable systems? Interesting.
I just typed in fsolve([eq1,eq2],[x,y],[11.3,302.5]) and it returned [11.316938475 302.475831894] which was the answer I was looking for ,but if I first have to plot the system, then it could be faster if I just Trace-found intersections on Advanced Graphing.
Anyway, thanks guys you helped me a lot.
RE: How to solve this non-linear system of equations? - alexzkter - 07-02-2014 05:58 PM
(07-02-2014 05:42 PM)slawek39 Wrote:  Software Version (6030)
and
Why {0..12,-100..0} ?
I was looking for positive only solutions between 0-360
There are several ways to do this, but never on 1 step only procedure unless you have a drawing on which you can rely on, like I wanted to do so.
RE: How to solve this non-linear system of equations? - parisse - 07-02-2014 06:54 PM
For exact data *and* polynomial system, you can find all solutions in theory, therefore conditions on variables *could* be checked. For everything else, there is no hope. The best I can imagine is to compute a grid of points in a given product of intervals, find the smallest in absolute value and start an iterative algorithm with this guess.
This is really something everyone should understand before using fsolve/solve and so. Sorry, no blackbox here...
