HP-67 1705A01234 [erase other's cards, writes and sometime read back its own cards] - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP-67 1705A01234 [erase other's cards, writes and sometime read back its own cards] (/thread-17729.html) |
HP-67 1705A01234 [erase other's cards, writes and sometime read back its own cards] - albertofenini - 11-20-2021 10:43 PM Hi everyone This is quite a weird one .. Any card previously written is erased when read by this HP-67 This happens also with what it should be a write protected corner clipped card It is however a blank card, recorded and than corner clipped I have checked what was obvious to me i.e. : the W/PRGM switch really switches from one state to the other as it should PGMSW pin at CPU board connector only goes to GND only when W/PRGM switch is moved I still have to try if the HDS and WPS sequence is correct when a card write protected and one not write protected are inserted I have written a simple program (math operations) recorded it with this HP-67 and while it is not read by any other HP67, it is sometimes read back by this unit This happens since I have slightly adjusted the pressure of the wheel While I have not been able to record CA and CB, I have successfully recorded RA and RB when reading a card and WA and WB when writing a card. As always, any help will be greatly appreciated! Take care !!! Pictures here : HP-67 1705A01234 RE: HP-67 1705A01234 [erase other's cards, writes and sometime read back its own cards] - teenix - 11-21-2021 12:04 AM The write protect checking is not activated when reading cards so shouldn't have any effect. The only way the cards can be erased while reading is if a current is passing though the heads, or the head is magnetized somehow. I can't see any other way. However, you say the cards can be read back sometimes, so maybe not erasing, but not writing properly. If you released pressure on the card adjustment it may make the card write weaker because the head is not in proper card contact. Try changing it back or increasing the pressure a bit and see what happens. Make sure WE stays at a LOW level all the time when reading. cheers Tony RE: HP-67 1705A01234 [erase other cards, writes and sometime read back its own cards] - albertofenini - 11-21-2021 12:43 AM Thanks Tony I’ll surely check it Still, it fails me how is it possible that just reading a card can damaged it so that any other unit, including the one that has originally recorded it, will not be able to read it again … I’ll check it better tomorrow and let you know When you says “make sure WE stays low” you mean it has to be ground connected right? And when it should go low and how long it should stay low ? Thanks !!! RE: HP-67 1705A01234 [erase other's cards, writes and sometime read back its own cards] - teenix - 11-21-2021 12:51 AM (11-21-2021 12:43 AM)albertofenini Wrote: Thanks Tony WE stays Logic LO when reading and probably stays LO all the time when idle. If it goes Logic HI, the write circuits become active which is undesirable for any other mode than writing. If WE goes HI when reading, it will affect the stored card data. cheers Tony RE: HP-67 1705A01234 [erase other's cards, writes and sometime read back its own cards] - albertofenini - 11-21-2021 01:07 AM Thanks again Tony By low you mean connected to ground ? By hi what do you mean? Take care and thanks RE: HP-67 1705A01234 [erase other's cards, writes and sometime read back its own cards] - teenix - 11-21-2021 01:39 AM (11-21-2021 01:07 AM)albertofenini Wrote: Thanks again Tony Logic LO would be close to zero volts. Logic HI would be somewhere between 4 and 6 volts. I can't remember exactly. cheers Tony RE: HP-67 1705A01234 [erase other cards, writes and sometime read back its own cards] - albertofenini - 11-21-2021 09:03 PM Hi Tony, Hi everyone I did some further troubleshooting and this is what I discovered ... WE stays LO all the time (when reading) A known working CPU board moved in this chassis with the original card reader doesn't work A known working CPU board AND a known working card reader moved in this chassis don't work either This card reader in a known good chassis works with a good known CPU board This card reader and this CPU board in a known good chassis both work fine However, this CPU board in any of the other three faulty HP67s I have is not working except for one combination It must be said that in this chassis the upper left and middle left screw holes (with keys face down) are worn out, and this probably is preventing a good contact between the card reader switches and the keyboard PCB, although the switches closes correctly when a card is read I have reinforced these two holes by inserting a small wire before tightening the screws and it seems to stay together well, however the calculator doesn't read nor writes, in a way it is worse than yesterday, but I think I may have isolated the problem with the chassis Also, after this tests and all this handling now it is not damaging cards where reading which is good I have updated the photo album with a capture of RA and RB when reading, they look normal to me but at the end of reading the "Error" message always shows up One more thing I may try is to change the "screw" that goes thru the card reader wheel, when rotating that in order to have more or less pressure on the card it does not move the wheel, so it may as well be that the problem Thanks for any advice you want to share, take care !! Updated pictures here : HP-67 1705A01234 RE: HP-67 1705A01234 [erase other's cards, writes and sometime read back its own cards] - teenix - 11-21-2021 11:33 PM I learnt that the card switches can be finnicky if the chassis is distorted or if they are not adjusted properly, probably from bent contact fingers. These problems might upset the timing of the switches and confuses the CRC. When the keyboard PCB is positioned in the front panel, it should sit flat on the mounts that are moulded into the front panel with no rocking. If it doesn't sit flat when the screws are tightened, the assembly will warp and put twisting forces on the switch contacts. Sometimes the power wires can get in the way too. cheers Tony |
