Is there hope for this HP 41C? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Is there hope for this HP 41C? (/thread-17739.html) |
Is there hope for this HP 41C? - mustiman - 11-22-2021 06:12 PM Greetings all. I hope this is the correct place to ask this question...here it goes: this beauty is on sale on a local second-hand website. The question is, is there hope? Thank you in advance for any insight, and kind regards. [attachment=10055] [attachment=10056] [attachment=10057] RE: Is there hope for this HP 41C? - Dave Frederickson - 11-22-2021 07:17 PM If that's the only corrosion then it looks like all you need is a golden zebra and an Expansion Port block. HP Calculator Parts and Services can be found at the top of the Articles Forum, here. https://www.hpmuseum.org/forum/thread-10769.html But you'll probably want to start out at The Calculator Store. https://www.thecalculatorstore.com/epages/eb9376.sf/es_ES/?ObjectPath=/Shops/eb9376/Categories/The_HP41_corner RE: Is there hope for this HP 41C? - Diego Diaz - 11-24-2021 07:39 PM Hi, It will help if you could also share some pics of the internal boards (where corrosion may have also found its path) and the screw post (frequently cracked/damaged). It often requires deep cleaning for the former and some fixing work for the latter. The I/O Flex is available; contact me in case you decided to go ahead with the repair job. And you can get a repacement Zebra stirp from José. Best wishes and good luck with your 41. Diego. RE: Is there hope for this HP 41C? - floppy - 11-24-2021 08:10 PM It depends of where you are. In Germany is Raymond the best of the best for repair of anything. I can give the contact mail via PM. RE: Is there hope for this HP 41C? - mustiman - 12-07-2021 01:36 PM Thank you Dave, Thank you Diego, Thank you floppy I decided against buying this, will be too much of a hassle to procure the parts (and possibly, borrow the expertise to do the correct surgeries) to where I am now. This looks a bit more complicated than I previously thought. Kindest regards to all! Musti. |
