Principal Stresses Program - help sought - Printable Version
+--- Thread: Principal Stresses Program - help sought (/thread-17755.html)
Principal Stresses Program - help sought - trs32596 - 11-26-2021 11:42 PM
Hi there,
Having trouble creating a program to solve the principal stress equation. This is done by finding the roots of the third order polynomial.
Here is an example of input data:
σx = 60MPa σy =-30MPa σz =-20MPa τxy =40MPa Tyz = 0, Tzx = 0.
Using the normal equation:
σ^3 −(σx +σy +σz )⋅σ^2 +(σxσy +σxσz +σyσz −τxy^2 −τyz^2 −τzx^2 )⋅σ −(σxσyσz +2*τxy*τyz*τzx −σx*τyz^2 −σy*τzx^2 −σz*τxy^2)=0
produces roots of -45.21, -20.0, and 75.21MPa.
My goal is to create a simple program to do this with the input data.
EXPORT PrincipalStressCoeffs(X,Y,Z,L,M,N)
LOCAL C1:= (X+Y+Z);
LOCAL C2:= (X*Y+X*Z+Y*Z-L^2-M^2-N^2);
LOCAL C3:= (X*Y*Z+2*L*M*N-X*M^2-Y*N^2-Z*L^2);
LOCAL r = CAS( proot([1, -C1, C2, -C3]) );
RETURN(r);
This code ends up returning imaginary numbers and not the same roots. Any help would be much appreciated.
RE: Principal Stresses Program - help sought - Edwin - 11-27-2021 04:48 PM
(11-26-2021 11:42 PM)trs32596 Wrote:  Hi there,
LOCAL C1:= (X+Y+Z);
RETURN(r);
You can simply calculate the eigenvalues
EXPORT PrincipalStressCoeffs(σx,σy,σz,τxy,τyz,τzx)
    LOCAL StressTensor:=[[σx,τxy,τzx],[τxy,σy,τyz],[τzx,τyz,σz]];
    RETURN(EIGENVAL(StressTensor));
RE: Principal Stresses Program - help sought - trs32596 - 11-27-2021 07:13 PM
Thanks Edwin!
program works great and I completely forgot about doing eigenvalues.
Thanks again!
RE: Principal Stresses Program - help sought - roadrunner - 11-27-2021 07:25 PM
To fix the OP's program, change this line:
to this:
LOCAL r = CAS("proot([1, -C1, C2, -C3])");
-road
