Program works in real, not virtual - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Program works in real, not virtual (/thread-17799.html) |
Program works in real, not virtual - Tonig00 - 12-06-2021 07:32 AM Helo I have written a short program: EXPORT ElM1(n,f1,f2) BEGIN LOCAL m1; rowSwap(IDENMAT(n),f1,f2)▶m1; RETURN m1; END; And it works in the real calculator (ROM 2.1.14597) changing the rows of a Identity matrix, but gives me error in the virtual one (ROM 2.1.14592): "rowSwap(IDENMAT(n),f1,f2) Error: Bad Argument Type" Do you heve some idea how to solve this small error? Thanks very much Toni RE: Program works in real, not virtual - roadrunner - 12-06-2021 04:23 PM For me your program runs from Home fine but fails when run from CAS. See C.Ret's answer here: https://www.hpmuseum.org/forum/thread-17790.html I think it's the same issue. -road RE: Program works in real, not virtual - Tonig00 - 12-07-2021 09:33 AM Thanks very much for your answer. In my real calculator it works both modes: CAS and HOME. But you are right in the virtual one, it works in HOME and not in CAS. There are some things that still do not understand in the thread you suggest: I have changed to EXPORT ElM1(n,f1,f2) BEGIN LOCAL m1; RETURN rowSwap(IDENMAT(n),f1,f2); END; And still gives me the same error in CAS Well at least works in virtual-HOME and in any mode in real. Thanks Toni RE: Program works in real, not virtual - roadrunner - 12-07-2021 03:29 PM Try this: EXPORT ElM1(n,f1,f2) BEGIN LOCAL m1; RETURN CAS(EVAL("rowSwap(IDENMAT("+n+"),"+f1+","+f2)); END; On the emulator works for me in CAS and Home. -road RE: Program works in real, not virtual - Tonig00 - 12-07-2021 05:53 PM Helo Thanks very much for your ideas. It works, both (HOME and CAS) on the virtual calculator. If this is useful for other programs, and you heve some doc on this, please let me know. If not, I will just try with this ideas. Thanks again Toni RE: Program works in real, not virtual - roadrunner - 12-07-2021 07:10 PM The only document I know of on running CAS commands from PPL other than the users manual is here: https://www.hpmuseum.org/forum/attachment.php?aid=3547 It may be somewhat outdated with with the current update though. Generally, if you want to run a CAS command from a PPL program you have to use this format: CAS(EVAL("a string exactly like what you would type on the CAS command line")) I don't think that's always required so you have to experiment to find the best method for any particular application. -road RE: Program works in real, not virtual - Tonig00 - 12-08-2021 09:26 AM Very interesting I will try Thanks very much |
