HP Connectivity Kit & Linux - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: HP Connectivity Kit & Linux (/thread-17818.html) |
HP Connectivity Kit & Linux - gour - 12-15-2021 06:21 AM Hello, am I right that Linux users are out of luck to have HP Connectivity kit working under Linux OS? If this is so, then it means that HP Prime calculator is of not much use for Linux users since the calc is not visible to the OS, its firmware can't be updated etc.? RE: HP Connectivity Kit & Linux - Thomas_Sch - 12-15-2021 08:08 AM (12-15-2021 06:21 AM)gour Wrote: Hello,Could it be an option to use Connectivity Kit etc. with Wine? https://en.wikipedia.org/wiki/Wine_(software) RE: HP Connectivity Kit & Linux - gour - 12-15-2021 08:46 AM (12-15-2021 08:08 AM)Thomas_Sch Wrote: Could it be an option to use Connectivity Kit etc. with Wine?That would certainly be an option - I'm using it with several apps I need - but according to this thread it seems it does not work any longer with newer revisions...Any update on it? RE: HP Connectivity Kit & Linux - Thomas_Sch - 12-15-2021 10:01 AM (12-15-2021 08:46 AM)gour Wrote:Sorry, but I don't have an update.(12-15-2021 08:08 AM)Thomas_Sch Wrote: Could it be an option to use Connectivity Kit etc. with Wine?That would certainly be an option - I'm using it with several apps I need - but according to this thread it seems it does not work any longer with newer revisions...Any update on it? Please address this topic directly to Mr. Kuperus (see other threads) and also to Tim Wessman/Cyrille with the request for public response. RE: HP Connectivity Kit & Linux - nickapos - 12-15-2021 11:53 AM (12-15-2021 08:46 AM)gour Wrote:(12-15-2021 08:08 AM)Thomas_Sch Wrote: Could it be an option to use Connectivity Kit etc. with Wine?That would certainly be an option - I'm using it with several apps I need - but according to this thread it seems it does not work any longer with newer revisions...Any update on it? I have used connectivity kit with wine, and it works for slightly older versions. I was able to connect my virtual calculators to it but not my physical calculator. In any case if you upgrade version it breaks. RE: HP Connectivity Kit & Linux - gour - 12-16-2021 07:00 AM (12-15-2021 11:53 AM)nickapos Wrote: I have used connectivity kit with wine, and it works for slightly older versions. I was able to connect my virtual calculators to it but not my physical calculator. In any case, if you upgrade version it breaks. Thank you for confirming it! This is now the reason that, despite some possible advantages in comparison with e.g. DM42/DM41X, I've eliminated Prime since I'm exclusively using Linux with only Wine for some apps for quite some years (since 1999.) RE: HP Connectivity Kit & Linux - nickapos - 12-16-2021 09:12 PM (12-16-2021 07:00 AM)gour Wrote:(12-15-2021 11:53 AM)nickapos Wrote: I have used connectivity kit with wine, and it works for slightly older versions. I was able to connect my virtual calculators to it but not my physical calculator. In any case, if you upgrade version it breaks. Yeah, prime is a great machine, but it is locked down and I do not see how you could transfer programs without using one of the officially supported platforms. Even Mac is a little bit behind in connectivity kit versions. RE: HP Connectivity Kit & Linux - denis - 09-18-2023 09:26 AM Hi, I'm now able to connect my Prime using connectivity kit on Linux. What did't worked for me: wine: no connection with the Prime even if the application starts correctly. Virtualbox Windows 7 No success with the connectivity kit 64 bits What works for me: Virtualbox , windows 7, connectivity kit 32 bits, USB in 2.0 (1.1 no driver and 3.0 didn't work) let the driver automatic install when you activate the hp Prime connection (icon on bottom right right click on Hp Prime) that's it ! RE: HP Connectivity Kit & Linux - Insoft - 09-20-2023 08:30 PM I use Windows 10 on a spare PC laptop for running HP Prime Connectivity Kit as macOS version is terrible the simulator is out of date. For simple file transfer the macOS version does the job but testing any apps it’s out of the question just too unstable out of date and high energy warning ⚠️ fan spinning up. One can transfer data to the HP Prime via an Arduino Leonardo |
