join the points of a graph using lines - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: join the points of a graph using lines (/thread-17857.html) |
join the points of a graph using lines - robmio - 12-27-2021 05:37 PM Good evening everyone, I have a question: can the HP PRIME calculator join the points of a graph using lines? Is it possible, using the "Statistics 2Var" APP, to draw a graph as in the attached figure? Best regards, Roberto. RE: join the points of a graph using lines - Didier Lachieze - 12-27-2021 05:49 PM Yes it’s possible : check "Connect" on the second page of the Plot Set-up in the Statistics 2Var app. RE: join the points of a graph using lines - robmio - 12-27-2021 06:00 PM (12-27-2021 05:49 PM)Didier Lachieze Wrote: Yes it’s possible : check "Connect" on the second page of the Plot Set-up in the Statistics 2Var app. Very good! Thanks a lot, Roberto |
